Injectors ??????,s
From Goulburn NSW
Hey guys,
is there any gain in performance between 11mm and 14mm,side feed,top feed fuel injectors?
Posted on: 2016/6/7 3:49
Re: Injectors ??????,s
No performance gain. High-flow injectors are available in top-feed as well as side-feed versions
There is no real advantage to side-feed or top-feed, except in manufacturing methods and packaging considerations. To switch from one type to another means changing the entire fuel rail
jpg  top-feed_fuel_rail.jpg (44.68 KB)
174_575699f2ad473.jpg 600X244 px
jpg  side_feed_fuel_rail.jpg (30.69 KB)
174_57569a01e7dde.jpg 640X224 px
jpg  S13_SR20_fuel_rail.jpg (61.01 KB)
174_57569a0a832e6.jpg 992X320 px
Posted on: 2016/6/7 10:55
Re: Injectors 11m vs 14mm
11mm vs 14mm refers to Top-Feed style injectors and is the inlet O-Ring diameter. No performance gains, which type you need depends on the size of the openings in the fuel rail
Hi-flo injectors are available in 11 or 14 mm inlet versions, you can get 1000cc injectors with 11mm inlets (stock CA18DET is 370cc)
Dimension 'A' - injector inlet O-ring
jpg  injector.jpg (14.00 KB)
174_5756a049d2e13.jpg 256X416 px
Posted on: 2016/6/7 11:22
