Where to Buy Head Gasket Kit?
From Sydney, NSW
Hi all! Looks like the a12 has finally done a head gasket.
Just wondering the best place to get a kit and when replacing is there anything else I should be looking at maintenance wise at the same time?
Cheers,
Tom
Posted on: 2016/6/6 4:24
Re: Where to Buy Head Gasket Kit?
Nows the time to repalce the valve guides if it has been smoking after starting. Otherwise, there's nothing of maintenance to be do
After you get it replaced, be sure to retorque the head bolts every 2 years to keep the gasket in shape
Posted on: 2016/6/6 5:19
From Sydney, NSW
Thanks DD that's exactly the type of info I needed :)
Posted on: 2016/6/6 5:32
From Sydney, NSW
Finding valve guides has proved pretty difficult for an a12 unless ordering from bprojects which seems pricey?
Posted on: 2016/6/21 2:22
From Adelaide
These guys had them when I bought them (http://www.autosurplus.com.au/), from memory they were 5-10 each, it was a while ago. I got a set of main bearings from these guys http://www.reflexeng.com.au/, they had them in stock since the other guys had run out. They might also have parts like that.
Otherwise you can get lucky calling a place like Repco or Autobarn who probably wont have them but might know who will. Another avenue might be contacting a head reconditioning place, they'd know where to get them.
Posted on: 2016/6/21 3:07
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Sydney, NSW
Thanks very much! I'll get in touch with them :)
Posted on: 2016/6/21 3:17
From Goulburn NSW
Posted on: 2016/6/21 3:19
Entire engine gasket kit is $63 USD direct from Bprojects website
Bproject sells racing valve guides about $180/set of eight
Nissan sells stock valve guides for $6.16/each. Oftentimes only the intake guides need to be changed (test the guides, yours may be OK)
And of course the forklift places sell them
google search
Posted on: 2016/6/21 3:51
From Melbourne, Australia
www.precisionintl.com has a lot of parts as well, valve guides for less than $5 each (cast iron) and a full gasket kit for $60.
Posted on: 2016/6/21 7:40
From Sydney, NSW
Thanks Slep3r the guy that did the old heads on my mini panel van just suggested precision as well! I'll give them a ring :)
Posted on: 2016/6/21 7:56
