Browsing this Thread:
2 Anonymous Users
Swaybar Question |
Hey guys,
For those running A15 engines in their lowered datsun 1200s, is the swaybar very close to the a15 sump?Whats the clearance distance between the sump and the swaybar?
Im thinking of running thicker swaybar mount bushes?? Im running a 120y swaybar. Any ideas?
Also did early 1200s run different swaybars as compared to late 1200s?
Thanks in advance
Posted on: 2016/5/28 3:34
Re: Swaybar Question |
Registered Users Contentmaster Usermaster
It's exactly the same shape sump as the A12. Clearance is the same (A15 oil pan is slightly wider in the bulges on the sides)
Posted on: 2016/5/28 7:59
From Mordialloc Victoria 3195
When I put the 120y swaybar on my A15 1200 ute, yes it 'just' rubbed on the sump. A gentle bit of 'percussion persuasion' (about 3mm) worked perfectly
Posted on: 2016/6/22 6:12
'79 B120 ute(TURBO EFI A15 + 60 ser.5spd ) '83 Clubman 7 ( TURBO EFI A15 + 63 ser.dog 5spd ) '73 KB110 Coupe Mild A15 5spd ( Quad carb revver soon) keep it simple
Thanks zigmondo Its slightly rubbing at the moment. How did you "pursuade" yours so i can do the same lol? Cheers
Posted on: 2016/6/24 14:49
Turn it over, so that the 'dip' in the B210 sway bar is installed down, so that it clears the engine sump
Posted on: 2016/6/24 21:30
