« 1 (2) 3 4 »
Re: NISSAN S13 BRAKES
I've heard that -- in some countries -- Turbos have the large brakes and non-turbos have the small brakes. In Japan-market it is more complicated
* Early S13: CA18
* Late S13: SR20
Apparently, top-of-the-line cars have the large brakes, no matter whether turbo or non-turbo, SR or CA. Seems like 4WS or Turbo have them
Same for Q's
* Q's
* Q's Diamonds
* Q's Club Selection
Posted on: 2016/8/5 1:35
From Lisbon
hI!
Can i change Datsun 1200 front wheel hubs?
I have two spares, but i dont know if they are from the same side (Exist right or left side?)
Posted on: 2016/8/7 23:18
Yes, the same hub is used on left or on right
Posted on: 2016/8/7 23:21
From Lisbon
hI!
The SR20DE that i told you has 257mm front rotors
You told me the Caliper differs from the 250 or 280 caliper. Brake pads are also different shapes.
I have new 255mm front rotors from CA18DET. The 257mm brake calipers from the SR20DE it is equal from CA18DET?
Posted on: 2016/8/9 9:03
255 mm front rotors? I'm not familiar with those
* In Japan, no 255 mm rotor was used with S13
* Same in North America
Nissan Europe, my information says:
S13 200SX 0988-1293 CA18
[257 mm] 40206-71E01/40206-71E02 0988-0991
[280 mm] 40206-55F01/40206-55F03 0991-1293
I'm not aware of any S13 that uses 257mm rotors and SR20 engine. Do you have a part number or year? The USA S13 uses 257mm rotors with the 2.4 liter engine
Posted on: 2016/8/9 9:54
They are 250mm rotors and calipers from Australian 1988~1989 Nissan Silvia ca18det
Posted on: 2016/8/9 11:17
Car free
From Lisbon
Can i use in 250mm rotors, a brake caliper from a s13 with 255mm rotors?
Posted on: 2016/8/9 11:23
Yes, with a custom adapter. S13 struts are the same, so the calipers are different heights to suit the rotor
Notice this photo of S13 calipers. The left is for smaller rotor, the right is for larger rotor. The u-shaped bracket is a different height
Posted on: 2016/8/9 11:32
From Lisbon
Thanks
Posted on: 2016/8/9 11:41
From Lisbon
hI!
Im in trouble.
I have install my new Datsun 1200 engine with twin Carbs and i have no clearance to the brake master cylinder.
At the moment i dont have a solution. I ve searching a RHD brake master cylinder but i m not sure if they fit?
Im all ears, let me know what is the best solution.
Thanks
Luis
Posted on: 2016/9/8 21:20
« 1 (2) 3 4 »
