a15 head on a12 71
From Sydney Australia
Heres the situation im in-
I have a 71 1200 with standard a12
A mate is selling me a complete turbo set up every thing i need (its off an a14) but i just realised that the exaust and intake manifold will be different bolt holes and different size ports!
So do I -
Change the head to an a15(heard its better than th a14 head)?
Change the engine to an a14?
Any sujestions would be appriciated
also would the a15 head lower the compression a bit cause this would be an advantage too?
Thanks
Posted on: 2004/6/20 6:31
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: a15 head on a12 71
From Christchurch NZ
If you change the head to a15 you will need to modify the oil feed to the rockerarms if your motor is the early type with the dizzy ay the front.
Posted on: 2004/6/20 7:07
Forced Induction!
Cheers i read that in another post i think it was you aswel (a14force).
Wich of the two is the better way?
Posted on: 2004/6/20 12:23
From Melbourne, Australia
go for an a-14 or a-15 motor if it fits the budget
for a street driven car the extra torque at low revs (off boost) will make it much nicer to drive
and the extra cc's are never gonna hurt
that said the exhaust manifold from the a14 setup would bolt up to an a-12 perfectly anyway, it's just the inlet you would have to swap, which shouldn't really be a problem anyway?
Posted on: 2004/6/20 12:31
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Thanks 1200 rallycar i am inquiring about an a14 in the classifieds section.
When i get the set up i will know for sure, when i actuall try bolting it up who knows what will happen!
Posted on: 2004/6/20 13:02
