1979 Datsun 210/310 Pushrod Help.
Good Morning first time poster been on your forums for helpful information all the time and thanks. I am currently restoring a 1979 Datsun 310 wagon and had recently found some bent pushrods after doing a compression test that failed. Unfortunately the Melling MPR-348 Pushrods are no longer available and was hopping your fine contributors may have a lead on eight pushrods to purchase. I am in California in the Sierra Nevada's and have struck out at this point. These push rods have the non standard end. Another question is there any rocker arm conversion kits for a more standard ball style pushrod end for a more available push rod if none can be found?
Thanks,
Mike
Link to image of pushrod but not in stock at any parts store that I have found.
https://www.summitracing.com/parts/mel ... NH30Kmq0M4CFYsfhgodA48ETA
Posted on: 2016/8/20 16:57
Re: 1979 Datsun 210/310 Pushrod Help.
Quite a regular
From Sydney
The easiest way to obtain them would be genuine, I assume. I'm guessing you have an A14? You can search "push rod" in the wiki and find the part number. I had to order two myself, and I used www.amayama.com. I'm not sure if you being in the U.S would make a difference.
Posted on: 2016/8/20 17:56
Motor is a A12 thanks for the link could not find the correct pushrod on the site.
Posted on: 2016/8/20 20:59
Welcome to the site.
Pushrods are readily available and were fitted to millions of engines. Nissan part number 13238-H1001
* HGM Forklift parts - buy online
* Buy online - Bprojects
* Picknpull in Sparks has a 1979 Datsun 210. If it has the A12A engine it will have what you need. Don't bother to call, they are completely self-service and you can remove the parts yourself
Would I buy used pushrods? You betcha, it is rare for them to fail they usually last forever. Causes of failure include too tight an adjustment or severe pinging
A 1979 in California/Nevada should have the A12A engine, which is bigger than the A12
Check your engine compartment ID plate
So you have a Datsun 310? Can you post a photo of the wagon? We like photos
The one in Sparks is a Datsun 210 (B310) but uses the same engine type as a Datsun 310. But if it has A14/A15 then the pushrods won't fit the A12A
Posted on: 2016/8/20 23:38
Thank you for the info and links much appreciated. I called the guys at pick and pull and will have a chance to hit their yard in a few days. Ill post some pics soon, this datsun was given to me for free with 75k miles on it been having fun restoring it. Cheers!
Posted on: 2016/8/21 22:42
