Build update and good body shops Reno?
Not too shy to talk
From Fallon,NV
It has been a while since I've been on here so I'd thought id give and update on my project plans. I moved so these might take a while to come to fruition and my car is pretty rusted so I'm already a step behind.
possible specs:
eninge:
07+ QR25DE
Trans:
05+ Frontier 5 speed
Diff:
MADDAT modified R31 differential with LSD
Major body mods include:
Trans tunnel
Hakotora kit
ducktail spoiler
possible colors:
interior; stock white
engine bay; white or something oil resistant (like rhino liner)?
exterior; skyline silver or gunmetal?
Some things I'm unsure about on this build are:
Radiator: How much is overkill and how much is too little?
Coilovers: upgrade to something else or has anyone tried the Ceika custom 1200 coilovers?
Brakes: this is pretty much depends on if I swap the struts or not.
Lastly does anyone know of good Body shops in Reno? I would like someone who is decent at fabricating and is a good person to work with. It can be pretty difficult to judge without other peoples opinion. Everything I've seen so far is either American hotrods or lifted trucks.
Thanks for your opinions
and
Posted on: 2016/9/10 2:28
Re: Build update and good body shops Reno?
Glad to see you still have your 1200
Awesome plan. I think yours is the first QR swap. The 2007+ is fixed for high RPM use (early QRs shouldn't be revved over 6100 RPM continuously) -- they strengthened the rods & pistons and (at least in some models) got rid of the power-robbing unnecessary balance shaft
If you decide to keep the 1200 struts you can fit the large vented disc brakes from the JDM S13 (280mm), or even the 257mm rotors from USA S14 will stop the 1200 and pull up hard. The main reason to swap struts is to gain more choices of bargain strut inserts -- but there are several choices available still for 1200 struts, from smooth-riding Nissan originals, ultra-short inserts for radical lowering, and adjustable racing inserts
Posted on: 2016/9/10 2:50
Not too shy to talk
From Fallon,NV
I'm actually looking at the spec v engine which comes with a higher compression ratio and 200hp stock with 174 ft lb torque.
Posted on: 2016/9/10 3:47
Awesome. How much radiator is enough? One that can cool a 200 hp engine! The B14 radiators fit in the 1200 and if you get a 3-row might be enough. They were only SR20DE, but they sell upgraded radiators that can support more power, the "2-row" (1-1/4 thick) unit is only $84 new aluminum radiator
The 2007 SE-R radiator is even less expensive but the are more than 2 inches taller so probably wouldn't fit
Posted on: 2016/9/10 5:45
From Las Vegas USA
There are a couple of vintage racers up near Reno. They'll be down here for vintage races at the end of the month and I'll ask them if they know of any shops. Is the top gun drag strip still there maybe some of those guys know somebody.
Tom
Posted on: 2016/9/13 3:57
Not too shy to talk
From Fallon,NV
Ok I was thinking that radiator would fit but I wasnt sure if it would habdle the heat. Im sure it will though.
Yeah the Top gun raceway is here. I havent been to any races yet but I will be pretty soon. Ive seen a couple of Zs but beyond that not a whole lot of of vintage japanese stuff beyond that.
Posted on: 2016/9/14 0:42
My brother recommends Jackson & Farmer Auto Body
Posted on: 2016/9/14 4:53
Not too shy to talk
From Fallon,NV
I found these Toms racing wheels and I thought they looked super cool but they are kind of small and super expensive. And in my looking atound I found these STR 527 rims. But they are 5x8 +15 offset. Has anyone tried this offset before? I already plan on a bunch of body work so its not the extra work. Id just like to see if people have tried it and if they have pictures. Much appreciated thanks.
jpg  images (13).jpg (9.31 KB)
16187_57ecc53bcc623.jpg 275X183 px
jpg  download (7).jpg (12.16 KB)
16187_57ecc5500a476.jpg 225X225 px
Posted on: 2016/9/29 8:40
I've had my eye on that type of rim. Looks like Tom's Igeta 3-piece? The STRs look better to my eyes
Do you mean 15x8? 8" is too wide unless you go with fender flares. As I recall 8" wide rims would require a -20 offset just to avoid hitting the strut (or you could use wheel spacers)
Posted on: 2016/9/29 9:27
Not too shy to talk
From Fallon,NV
Yeah 8" wide. The hakotora kit comes with fender flares so I was plnning an putting them on anyway. I was talking with the company and they only make it in this width at this offset. I thought spacers would work but thats just for street. Im pretty sure they arent allowed on the track. Right?
Posted on: 2016/9/29 23:08
