fuel steel hard line and an size for other lines
From Sydney, NSW
Hi just wondering when doing an efi upgrade of a mild street car for hard lines and engine bay lines for steel lines would 3/8" be ok? and an-6 or an-8 for the rest?
Thanks,
Tom
Posted on: 2016/9/11 7:15
Re: fuel steel hard line and an size for other lines
1/4" (6mm) line will be fine for up to 100 hp mild street engine
5/16" line is good for up to 250 hp
3/8" line is used by 7.4 lite V8 (or 375 HP turbo Nissans)
Posted on: 2016/9/11 7:28
From Sydney, NSW
So is 5/16 usually best mated with 6an fittings?
I'm thinking of doing it once and never having to swap it out again! famous last words :)
Posted on: 2016/9/11 7:40
Lots of nice setups do not use AN fittings. Millions of EFI vehicles with high-pressure fuel systems don't use AN fittings
If you like the looks, go for the AN system
Posted on: 2016/9/11 8:05
From Sydney, NSW
I actually don't really like the look of them I'd prefer something more classic
Posted on: 2016/9/11 8:08
From Snohomish, WA USA
I run 1/2 up and 3/8 on the return. Separate 3/8 line and pump for the wet nitrous. All AN fittings.
I'm guessing I'm over 375hp.
Posted on: 2016/9/11 21:35
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
