13201-H6200/13202-H6200 rod diameter?
From Sydney, NSW
Hi I found the wiki that the
The intake valve 13201-H6200 is 37mm the exhaust valve is 30mm
The length of both is 103.8mm
any idea what the diameter of the rod itself is?
Posted on: 2016/9/23 1:42
Re: 13201-H6200/13202-H6200 rod diameter?
From Sydney
If you are referring the valve stem diameter, they would be regarded as 8mm valve stems
Posted on: 2016/9/23 2:30
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney, NSW
That's the one! thanks benny!
Posted on: 2016/9/23 3:02
Yes, all A-series engines use 8mm valve stems. For higher flow, 7mm valves can be used if the valve guides are replaced with 7mm guides
The actual diameter of the stem is around 7.95 mm (see Valves)
jpg  valve part names.jpg (19.80 KB)
174_57e5bd34bc9c9.jpg 362X439 px
Posted on: 2016/9/24 0:30
