Browsing this Thread:   4 Anonymous Users
« 1 ... 9 10 11 (12) 13 14 15 ... 18 »
Re: my new ride 1200 ute
Not bad, heavy on the blackout trim, but I like that
jpg  Before 13528915_10154025541659724_3362068361657317164_n.jpg (101.68 KB)
174_57d320403bc09.jpg 488X650 px
jpg  Before 13393968_10154025541599724_39079205954911111_n.jpg (76.08 KB)
174_57d32049e612d.jpg 867X650 px
Posted on: 2016/9/9 21:49
From Port Douglas. QLD
^ thats the before photo fyi
Posted on: 2016/9/10 0:32
1200 ute
ca18det
Wow! look tough! And aircon too
jpg  After 13686776_10154073283284724_7558389691504194202_n.jpg (142.51 KB)
174_57d3486293802.jpg 867X650 px
jpg  After 13654246_10154073283424724_4021602052696110229_n.jpg (131.51 KB)
174_57d3487c9737b.jpg 867X650 px
jpg  Bay 14117860_10154193605214724_784818096357533330_n.jpg (106.48 KB)
174_57d34885dee40.jpg 917X516 px
Posted on: 2016/9/10 0:41
Upgrade my tailshaft to something bigger and tougher
Good idea, reminds me of Tommo after he swapped in CA18 ... SNAP!
Posted on: 2016/9/10 3:43
Little update:
Fuel pump packed it in. Turns out the maddat unit supplied with their kit will not support high boost. Probably ok for stock ca18 though.
My diff also packed it in. I brought the r31 diff used from a drag ute so it was inevitable.
This has led me to decide to upgrade the fuel pump to a Bosch 044, rebuild the diff and while I'm at it I picked up Garrett GTX2867r brand new at a decent price. So a fresh tune and I'll report back with figures and drive ability over the disco potato.
What's next?
Well cpc inlet manifold, larger injectors, 6boost exhaust manifold, tunnel mod and rb25 gearbox. Then I am DONE!
I swear.
Posted on: 2016/9/30 11:28
1200 ute
ca18det
😂 done
Posted on: 2016/10/1 0:00
Car free
Must be making a lot of power
Are you sure the Borg-Warner 78 (from the R31) is going to be strong enough? I think they are only rated for 320-340 ft.lb. They are common here in the Camaros (aussie-sourced axles) but a lot of guys swap them for something stronger
* R31 Skyline: 28-spline 4-pinion
* R31 Pintara: 25-spline 2-pinion
Posted on: 2016/10/1 0:09
Im pretty confident the diff will handle the power. Its not excessive and im only aiming for 300rwhp on pump fuel. We dont have E85 up here in Cairns yet. It came out of a high horsepower drag setup ute.
Posted on: 2016/10/4 3:42
1200 ute
ca18det
Update:
So new turbo on, same-ish power with 10psi less boost. Haven't seen graphs or driven yet as the diff is in a million pieces.
Dropping down to 3.7 gears to make highway driving more tolerable. New truetrac lsd going in too.
Im really suss that my setup is letting me down and something is a miss. With all the components of the build i would expect ALOT more power than what im getting...To investigate further means more time pulling things apart. So its with workshop still as time is something i dont have. I think the timing was setup incorrectly.
Ive ordered 260deg camtech cams, adjustable gears, a 6 boost manifold and im also going to run an rb26dett ati balancer with some nice pulleys from Matt Eastgate.
Scored the cpc inlet manifold secondhand so that will go on too.
jpg  14991839_10154416825924724_1464485272873350390_n.jpg (35.38 KB)
16861_582c398d511ac.jpg 568X320 px
Posted on: 2016/10/20 10:24
Edited by mrbarista on 2016/11/16 10:48:50
1200 ute
ca18det
Ran at the drags...13.5 again on 200hp. It was 34deg and again the my fuel system is heat soaking.
I have ordered a fuel cell and will install this week. Quieter operation and more capacity.
Booked in for cams, manifolds and tune.
Fingers are crossed i see some good results after all of this.
Posted on: 2016/11/6 0:02
1200 ute
ca18det
