Browsing this Thread:
1 Anonymous Users
a14egi parts |
Hi guys, since im not going to use these parts, its for sale now.
a14e block, Camshaft (high rpm) , mechanical fuel pump delete plate, piston, conrod, crankshaft, timing gears, a/c compressor+bracket, oil pan, oil pump,
basically everything.
Posted on: 2016/10/18 5:14
Re: a14egi parts |
Registered Users Contentmaster Usermaster
Does it have the factory flat-top pistons? What is the compression gauge reading?
Posted on: 2016/10/18 8:52
Re: a14egi parts |
Country / Area?
Posted on: 2016/10/18 9:53
Re: a14egi parts |
From Little Rock, AR
Interested in the A/C bracket and compressor. Can you give a part number off the compressor? I don't know if I can get a new one here and that compressor looks rough!
Posted on: 2016/10/18 21:49
Re: a14egi parts |
* 27631-U9602 COMPRESSOR SWASH TYPE DKKC Datsun B310 A12/A13/A14/A15 Datsun 810 7802- some models * 27630-H8501/H8510 COMPRESSOR [with clutch assembly] * 11910-H7401 BRACKET-COMPRESSOR A14
A14E Compressor.jpg (21.84 KB)
Posted on: 2016/10/19 0:59
Re: a14egi parts |
hi
I cant turn the compressor. i guess the a/c is not in working condition. the number on the a14e a/c bracket is '9015105A K1'
i have another bracket written '5 speed datsun 120y ccc'
Posted on: 2016/10/19 3:57
Re: a14egi parts |
A14 and A15 bare block are same? if use a15 cranckshaft and piston in a14, it will produce the same power? the block no is M72
Posted on: 2016/10/19 4:01
Re: a14egi parts |
* M72 is an early A14 block * G34 is the A14/A15 block A15 crank fits early A14 block if the block is machined (notched) in the side. Also needs A15 oil pan
No need to swap the crank to make the same HP -- both A14E and A15E made 92 hp. The A15 crank & pistons will boost HP at lower RPMs, so it is an advantage, but not a huge advantage
Posted on: 2016/10/19 8:43
Re: a14egi parts |
It looks like most 1979-up Datsuns use the same compressor. The clutch somehow differs on them This label says OGURA CLUTCH 4070036 http://www.oguraclutch.co.jp/e/product/ac
ac clutch.jpg (37.53 KB)
Posted on: 2016/10/19 9:11
