« 1 ... 3 4 5 (6) 7 8 9 ... 12 »
Re: diff ratio and wheel size.
thanks mate!!!
I need to check my pipe diameter. doubt it is 2". if its bigger than 1.75", what will be the issue? can i keep the 4-1 extractor manifold?
Posted on: 2016/10/14 2:33
how about the dual outlet muffler?
Posted on: 2016/10/20 19:52
If the pipe is bigger than needed, you'll lose a few HP, but it will still run OK. On the plus side it will sound tougher
You can use any manifold you wish: 4-into-1, 4-into-2-into-1, whatever. To be as quiet as possible while maintain the power, I recommend the factory 4-2-1 cast manifold instead of a thin-wall tubular extractor. It will be much quieter while giving same power as un-tuned extractors
You can use any muffler you want, with single or dual outlet. To be as quiet as possible while maintain the power, use a larger-than-stock conventional muffler. Most performance mufflers are noisy, and do not outperform larger mufflers
Posted on: 2016/10/21 1:58
Twin SU Damper Oil
1st trip to Genting Highland, Malaysia(1740 meter) with my datsun. I can say it was an effortless steady hill climbing. should i thank the 4.11 diff?
On the other hand, there is no sudden acceleration if i floor the gas pedal. But better result if i slowly press the pedal along with the engine rev.
Does it mean i need a thicker SU damper oil?
jpg  genting highland.jpg (190.59 KB)
17554_580fa6223f606.jpg 937X527 px
jpg  genting.jpg (192.16 KB)
17554_580fa62e23665.jpg 847X476 px
Posted on: 2016/10/25 19:37
Nice photos. What brand are your wheels?
Sounds like it might be bogging down. I would use the recommended 20W or 10W-30 engine oil in the carburetors
Are they L-series carburetors? If so the needle jet might be too rich, you can try raising the needle by turning the idle adjusting nut in 1/2 turn. Just going from sea level to high elevation will make the carburetor run poorly but a quick adjustment along the way will fix it
Posted on: 2016/10/25 22:54
Thanks. Those are believed to be Performance Spitfire.
But with only stamp 'made in Australia'
13x7"
Yes its L carburetor with ATF as damper oil
Posted on: 2016/10/26 5:25
You might need to raise the needle a full turn. Try it at half turns and see
Best to replace the L-series needle with A-series needle, and A-series spring. I've heard that AFT is similar in viscosity to the recommended oil
Posted on: 2016/10/26 8:48
so the a12GX twin su will be perfect for my a15? If i managed to get another a12gx, i'll keep the twin su and only sell the rest..
Posted on: 2016/11/2 5:13
quick undercarriage wash. managed to snap some exhaust photos.
I went to 2 exhaust shops. one ask me to add a center muffler at the cat-converter place (red circle) and remove the sports muffler (yellow circle).
Another shop ask me to just replace the sports muffler to a largest standart muffler as possible.
i want quiet exhaust sound and high flow.
jpg  wash.jpg (189.51 KB)
17554_5819783f3a8c0.jpg 768X432 px
jpg  exhaust2.jpg (155.29 KB)
17554_5819784d8d596.jpg 432X768 px
jpg  exhaust1.jpg (175.35 KB)
17554_58197859c0421.jpg 738X416 px
jpg  exhaust3.jpg (170.76 KB)
17554_5819787128239.jpg 922X519 px
Posted on: 2016/11/2 5:24
can anyone advice what brand is this wheels? is 14" wheel with 6" width.
png  alloy wheels.png (194.93 KB)
17554_5842f354034a5.png 500X221 px
Posted on: 2016/12/3 16:32
