« 1 (2)
Re: 1200/B210 Strut inserts
From Castro Valley,CA USA
http://datsun1200.com/modules/myalbum/photo.php?lid=24045&cid=14
I remember the 361005 being the stock length cart insert. I guess not.
Either way, I used the bilsteins because the koni's were too fat in diameter.
your's turned out good.
Posted on: 2016/11/6 22:54
Hey ang.
what do you mean by the stock length cart?
the kyb strut i got was around 101mm shorter than the 120y(or 1200 since its the same front end strut/shocks) ones that i had ! :)
did you replace your rear shocks? if you did what did you use?
i flipped my rear leafs and its so low that now its on the bump stops haha. may have to cut some of it out.
and was this for your 1200 ute/sedan or b210/120y?
Posted on: 2016/11/7 6:18
Angelo has a Datsun 1200
1200 Sedan, Coupe and Ute strut inserts are all the same. Same specs too. 120Y is the same, but USA B210 is totally different (uses the PB210 large-size supsension with 2.0 inch strut tubes)
I cut 100mm from my strut tube and my shock lock nut that screws in up the top of the strut holds the strut down perfect.
How'd you do it? If you cut 100mm off the top, then the nut threads are gone. If you cut 100mm out of the middle, then do you need to weld the two halfs of the strut tube together?
Since the Golf inserts have a larger shaft, how did you get the lock nut back on? Did you drill it out larger?
The black cartridge says KYB, so is it the the one you put back in the strut?
jpg  aWI9Tdm.jpg (185.08 KB)
174_5833979d86bb1.jpg 640X1280 px
Posted on: 2016/11/22 0:55
Oh boy, I might have something mixed up regarding the black cartridges in my picture that I have labeled as "KYB 361005". I may have mixed something up on my end. I'll have to check it out.
Posted on: 2016/11/24 22:06
« 1 (2)
