« 1 2 3 4 (5) 6 7 »
Re: Project Avocado: 1971 B110 Coupe build - USA
The only LED lights I have are in the dash cluster for L and R turn... Is this still the reason why?
If they turn signals light up but won't flash, yes that's probably the reason
Posted on: 2016/11/25 7:44
From Snohomish, WA USA
I have LEDs throughout my dashboard. Turn signals/Flashers. They work fine. But of course I totally replaced my cluster and made my own. That really should not make a difference.
Posted on: 2016/11/27 1:00
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
I got a 50 50 chance the flasher DD posted will work. Bought it yesterday
Posted on: 2016/11/27 4:20
I'm more worried about the hood at the moment. I could try to beat the old one back in shape but a second hand one would be ideal. The hinges tore through part of the firewall too
Posted on: 2016/11/27 4:23
* With high-load LED lights, the stock flasher unit works fine
* With low-power LED lights, the stock flasher unit fails to flash
Use a modern flasher unit (3-wire type)
Posted on: 2016/11/29 5:43
My 1200 hood (bonnet) had a roof-dent in it for 10 years. Worked just fine. The hinges tore through the firewall, but still worked fine
The recall for was for the secondary latch (for if the hood was only partly closed). If it is completely closed, the latch works perfectly fine, regardless of whether it has the recall part or not
Posted on: 2016/11/29 5:44
Also, are the dash lights meant to illuminate when depressing the brake pedal or is this a wiring problem?
Posted on: 2016/12/2 0:38
No dash lamps should light when brake pedal is depressed. Causes
* brake system out of whack (BRAKE warning light)
Or
* wiring problem
CANADA/USA
BRAKE SYSTEM WARNING LAMP
If either half of the dual brake system fails, the brake warning light (BRAKE) glows when brakes are applied. You must stop the car immediately and if you can safely operate with two-wheel brakes, move your car at reduced speed to the nearest service station.
This warning light is also used as the parking brake warning light.
Posted on: 2016/12/2 4:32
Hmm I will look into this. The dash lights definitely illuminate when I hit the brakes but not the "Brake System Warning Lamp"
Drove it to work today:
Posted on: 2016/12/2 17:10
Nice seats!
Which lights illuminate?
There are nine lights in the dash
If the metal tab at the bottom is not bolted down (earthed), weird things occur with the lights
Posted on: 2016/12/2 22:20
« 1 2 3 4 (5) 6 7 »
