Is it possible to swap 60L 5th gear into 60A 5 speed?
From Las Vegas USA
The 60L uses a lower .854 5th than the 60A .821 5th; does anyone now if it's possible to swap these out? I'm looking to tighten up the ratios for my coupe.
Going to use the 60 series box with 4.62 R&P till I resolve the the issue of stringer close ratio box for my coupe (read pry open my wallet).
Tom
Posted on: 2017/1/6 6:08
Re: Is it possible to swap 60L 5th gear into 60A 5 speed?
it seems to me they won't interchange
* Overdrive gear in the 60L is the first gear on the mainshaft, and it matches up to the cluster shaft
* In the 60A it is the last gear on the mainshaft, and matches a gear bolted to the end of the countershaft
60L 5-speed for A14 engine
32340-H9000 GEAR ASSY-OVERDRIVE
32210-H9000 GEAR-COUNTER ASSY
60A 5-speed
32340-H9700 GEAR ASSY-OVERDRIVE
32215-H9700 GEAR-OVEDRIVE COUNTER
60A Overdrive
Posted on: 2017/1/6 6:58
From Las Vegas USA
Dave this falls under Duh!!! I've read.the tech wiki numerous times and know they changed the 60 series which is why there is a dog leg and non dog leg but for some reason I got it in my head that these boxes were like the 280ZXs where you can swap the ratios.
Tom
Posted on: 2017/1/7 4:15
