« 1 ... 44 45 46 (47) 48 49 »
Re: Datsun 1200 Sedan Build
From Trinidad and tobago
Custom tow hook!
jpg  16105566_10211782513988968_2455224645318885677_n.jpg (86.09 KB)
12526_587f25b5d56dc.jpg 720X960 px
jpg  16114550_10211782514068970_2118663553071690174_n.jpg (39.92 KB)
12526_587f25c27f7ae.jpg 960X960 px
jpg  16114853_10211782513908966_8256947479036787942_n.jpg (25.06 KB)
12526_587f25dba3d54.jpg 960X960 px
Posted on: 2017/1/18 8:23
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
installed my custom tow hook.all so went to get new tyres for the rear, will get better pics soon
jpg  IMG_6548.JPG (73.58 KB)
12526_587f27ada513e.jpg 490X490 px
jpg  IMG_6556.JPG (192.62 KB)
12526_587f28545bb9f.jpg 816X529 px
Posted on: 2017/1/18 8:34
Street Sleeper!
Ah, the 1200 on the jack, getting new tyres. Stance
Posted on: 2017/1/18 8:43
Got the rear tyres sorted out,after that the carby started to give some trouble when driving it was very uncomfortable,at low speeds it will have a flat spot and hesitation,it will idle very good no issues but at around 1500 rpm it will die out then pick back up,removed the top and rechecked all jets, checked float level and for air leaks ,it was a used carb that i got and had been on for about 4 years tho i figure its time,so i decided to go and get a new one from the performance shop.
Some pics of the carby.
Also as that was happening the charge light was staying on,rev her up and the light will come off,checked the voltage and it was somewhere at 14.05, so it was overcharging, i ruilled out the voltage regulator so it wasn't that, went to a local scrap yard and picked up an alternator from the Mazda 626 F6 8-valve SOHC engine,bolts straight on to the A series engine block no mods,all jacks plug in,just to rewire.By-pass the external voltage regulator? the electrician did that part for me.
Some pics!
jpg  SAM_5944.JPG (174.61 KB)
12526_58848b809caee.jpg 730X548 px
jpg  SAM_5947.JPG (196.06 KB)
12526_58848cf59002c.jpg 694X521 px
jpg  SAM_5948.JPG (179.95 KB)
12526_58848d0f34d38.jpg 730X548 px
jpg  SAM_5949.JPG (191.83 KB)
12526_58848d42b10a8.jpg 730X548 px
jpg  SAM_5950.JPG (196.39 KB)
12526_58848d47e20bf.jpg 730X548 px
jpg  SAM_5952.JPG (190.80 KB)
12526_58848d6677d2a.jpg 657X494 px
jpg  SAM_5959.JPG (188.34 KB)
12526_58848d8f5dfa0.jpg 657X494 px
jpg  SAM_5962.JPG (160.30 KB)
12526_5884906e3d7fe.jpg 730X548 px
jpg  15823723_10211632333234543_6266376681230093697_n.jpg (66.34 KB)
12526_58849667aebd8.jpg 720X960 px
Posted on: 2017/1/22 11:17
Street Sleeper!
Following day i was back at it again,put on the new carb 32/36 weber,its an original one too just as the previous.Fired her up and one tumble she started,set the idle and took her for a spin,whooo!!!! she runs sweet!
I have my mind set on rejetting soon!
jpg  16114613_10211823193405928_1662595942809551304_n.jpg (38.66 KB)
12526_588496ed0d78f.jpg 960X720 px
jpg  15823106_10211632332474524_3158809428818872233_n.jpg (63.30 KB)
12526_5884970dd4d67.jpg 960X720 px
Posted on: 2017/1/22 11:31
Street Sleeper!
Oh that looks good!
By the way, lead acid batteries (car batteries) require a charging voltage of about 13.5-15.5 volts depending on temperature. Here are the Datsun 1200 factory service manual specifications:
Posted on: 2017/1/22 22:53
Update-
Removed my old oil catch can and made a new one.The previous one the hose barbs were falling out, so i drilled the holes a little smaller and screwed them in,hold s up much better.
Got the front calipers from the Nissan Y11 series.Rotors are from the S13,Plan to use the 13'' wheels
jpg  SAM_5793.JPG (189.69 KB)
12526_589d1b057dcbf.jpg 519X692 px
jpg  SAM_5889.JPG (196.47 KB)
12526_589d1b4d1bafb.jpg 694X521 px
jpg  SAM_4339.JPG (197.41 KB)
12526_589d1c442f15e.jpg 692X519 px
jpg  SAM_4373.JPG (155.15 KB)
12526_589d1c4aedcd0.jpg 692X519 px
jpg  SAM_4444.JPG (163.96 KB)
12526_589d1c52bf9a2.jpg 588X506 px
Posted on: 2017/2/10 1:52
Street Sleeper!
Removed THe front struts. compared them to the stock 120y, they are tiny.
rotor to clearance is big so the caliper will fit well. more pics to come
jpg  15781391_10211632331794507_5800812199373974716_n.jpg (55.86 KB)
12526_589d2d7a53503.jpg 720X960 px
jpg  P11-08-14_1802_zps03195c50.jpg (72.43 KB)
12526_589d2d82781a8.jpg 1024X645 px
jpg  SAM_1734_zps397bda83.jpg (115.93 KB)
12526_589d2d898701a.jpg 1024X768 px
jpg  SAM_5987.JPG (198.10 KB)
12526_589d2e2944202.jpg 741X557 px
jpg  SAM_5997.JPG (189.99 KB)
12526_589d2eecced1b.jpg 630X475 px
jpg  SAM_6000.JPG (161.30 KB)
12526_589d2f02a3e46.jpg 548X411 px
Posted on: 2017/2/10 3:13
Street Sleeper!
Y11 = Nissan Wingroad/Nissan AD Van
Those brake pads look like the S13 250mm brake pads
Posted on: 2017/2/10 20:37
From Snohomish, WA USA
If you are not required to, don't plumb your crankcase blow-by back into your carb. You are just loosing HP. Plumb it into your exhaust. Let that Weber do its job.
Posted on: 2017/2/10 23:25
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
