« 1 (2)
Re: Adjustable Camber
From Trinidad and tobago
thanks for the reply guys could always count on yall for info, any idea how thick should the washer be?
Posted on: 2017/1/18 7:38
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
With brand new T3 tops, it may come with a spacer. Since T3 markets them "for Datsun 1200" they must have it figured out
Unfamilia, is this the spacer you used with your generic camber tops?
Posted on: 2017/1/18 9:15
No that was a washer to stop the top hat dropping further down shaft. Spacer was about 25mm tall. Little washer on top then pipe them big washer on top of top spring hat
Posted on: 2017/1/18 10:09
i don't really understand unfamilia,
Little washer on top then pipe them big washer on top of top spring hat?
what pipe?
Posted on: 2017/1/19 0:41
Street Sleeper!
Got a picture
jpg  IMG_20170123_011218.jpg (149.52 KB)
277_5884bde5ddbdb.jpg 391X460 px
Posted on: 2017/1/22 14:10
The stock spring seat is dished, so it needs a spacer. I reckon it could be two-piece (washer + spacer) or one-piece (washer welded to spacer)
Instead of the large washer, maybe use the stock bearing
Posted on: 2017/1/23 20:15
Spacer needs to be taller than the dish of the spring cup
Like this maybe
jpg  camber top with stock spring seat.jpg (26.01 KB)
174_58866b1bc77d1.jpg 400X560 px
Posted on: 2017/1/23 20:44
On second thought, the Factory Service Manual shows the upper spring seat upside down. I found this photo shows it the other way
Doesn't seem like it would need a thick spacer
jpg  1200 strut.jpg (30.73 KB)
174_5886f21550aac.jpg 304X544 px
Posted on: 2017/1/24 6:20
thanks for the info guys,
i have recently baught s13 coilovers and camber plates and decided to put on my 1200 sedan but i decided i will go for the smaller diameter springs and sleeve .i have removed the old shocks and got the sleeves,they are a bit dirty but i will clean them,what i really wanna ask u is where i cut my struts to put in the s13 sleeves if you'll have any measurements.i have seen work an will like to do it to my 1200,thanks much!!
jpg  SAM_6085.JPG (182.08 KB)
12526_58895ff097287.jpg 461X615 px
jpg  SAM_6087.JPG (175.06 KB)
12526_5889600c65d1c.jpg 615X461 px
jpg  SAM_6088.JPG (160.58 KB)
12526_588960133d420.jpg 615X461 px
jpg  SAM_6089.JPG (170.76 KB)
12526_58896043ee92d.jpg 615X461 px
jpg  SAM_6092.JPG (190.60 KB)
12526_5889606523f8d.jpg 425X567 px
Posted on: 2017/1/26 2:35
Street Sleeper!
No need to cut the existing strut. Just slide the sleeves on and fasten securely (weld or use an industrial shaft collar)
Posted on: 2017/1/26 3:35
« 1 (2)
