« 1 2 (3) 4 »
Re: 13B Rotary Swap
From St. Louis, MO
They are set up for the ford Pinto, I use the B310 struts, had to make a spacer for the ball bearing anr a a new bracket for the caliper. Only thing Im currently wotking is with the rear seal
Posted on: 2017/1/9 2:41
Re: 13B Rotary Swap
From St. Louis, MO
Latest update
jpg  IMG_0563.JPG (164.69 KB)
9861_5872fb4859fbb.jpg 1024X576 px
jpg  IMG_0566.JPG (180.21 KB)
9861_5872fb6d9ea27.jpg 1024X576 px
jpg  IMG_0565.JPG (166.79 KB)
9861_5872fbb4b27b2.jpg 1024X768 px
Posted on: 2017/1/9 2:56
Re: 13B Rotary Swap
From Mordialloc Victoria 3195
Also interested in which Wilwood 4 potters they are.
Are they these ones ? if not with a larger disc thickness
http://www.ebay.com.au/itm/2906167125 ... geName=STRK%3AMEBIDX%3AIT
These are 4 x 1 3/8" - so many different options ,trying to work out what piston bore size would be best for me
Posted on: 2017/1/9 6:46
keep it simple
Re: 13B Rotary Swap
From St. Louis, MO
I will let you know once I get home, had to make this bracket in order to install them
jpg  IMG_0582.JPG (141.35 KB)
9861_5873afc65f346.jpg 1024X576 px
Posted on: 2017/1/9 15:45
Re: 13B Rotary Swap
From Snohomish, WA USA
Impresive Stuff!!
Posted on: 2017/1/9 19:59
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Re: 13B Rotary Swap
From St. Louis, MO
These are the ones I use, Dynalite
jpg  IMG_0610.JPG (176.80 KB)
9861_58746930f00a1.jpg 850X1133 px
Posted on: 2017/1/10 4:55
Re: 13B Rotary Swap
From St. Louis, MO
Latest update, finally a roller
jpg  IMG_0828.JPG (147.27 KB)
9861_58869dd676965.jpg 800X600 px
Posted on: 2017/1/24 0:20
Re: 13B Rotary Swap
Looking sharp
Posted on: 2017/1/24 0:44
Re: 13B Rotary Swap
From St. Louis, MO
A few more
jpg  IMG_0833.JPG (133.03 KB)
9861_5886c82aef350.jpg 800X600 px
jpg  IMG_0832.JPG (124.97 KB)
9861_5886c83a146fe.jpg 800X600 px
Posted on: 2017/1/24 3:21
Re: 13B Rotary Swap
From Rosewood, QLD
mmmmm 2 door sedan with massive rubber.
Posted on: 2017/1/24 8:05
1971 B110 sedan project.
2012 Nissan Micra daily.
« 1 2 (3) 4 »
