1200 Lowering Guide
Found this on Yahoo Auctions (of all places! -- it will disappear after a while)
1200 Sunny Truck coilover installation reference pictures
Front: Fender hammer folded adjustment [フェンダーツメ折 車高調]
Rear: beating out overfender [叩き出しオーバーフェンダー] 100 mm low down leaf + 50 mm block
Photo 1
Front: 15 x 7.5 -5, 165/50R15
Rear: 16 x 8.5 -5, 195/40R16
* Rears are slightly taller tyre: 195/40R16 (22.1" diameter) compared to 165/50R15 (21.5" diameter) front
* More photos of 1200s with Panasport wheels: Panasport rims
jpg  Panasport G7-C8R.jpg (32.95 KB)
174_588727d9eb7d3.jpg 599X400 px
Posted on: 2017/1/24 9:54
Edited by ddgonzal on 2017/1/24 10:15:13
Re: 1200 Lowering Guide
http://page11.auctions.yahoo.co.jp/jp/auction/n194417136
Photo 2
Wheels
* Front: Presidio Demon Camber CST
* Rear: SSR Formula Mesh
15 x 8 -10, 195/45R15
画像2枚目
ホイール: 前 プレセディオ・デーモンキャンバーCST
後 SSR フォーミュラーメッシュ
前 15インチ 7.5Jマイナス5 165/50R15
後 15インチ 8Jマイナス10 195/45R15
jpg  Rear Forumula Mesh, front CST.jpg (34.25 KB)
174_58872d6d61e99.jpg 599X400 px
Posted on: 2017/1/24 10:24
badson_datsun
Photo 3
Wheel: Presidio Demon Camber CST
* Front: 15 x 7.5 -5 165/50R15
* Rear: 15 x 7.5 -5 195/45R15
Muffler: Matsuoka above diff. A gem that does not interfere with lowdown leafs & blocks -- wonderful. It is recommended because it is OK for vehicle inspection!
画像3枚目
ホイール: プレセディオ・デーモンキャンバーCST
後 15インチ 7.5Jマイナス5 195/45R15
マフラー:まつおか製デフ上マフラー
ローダウンリーフ&ブロックでも干渉しない逸品⇒素晴らしい
車検OKなのでお勧めです!
jpg  CST wheels.jpg (69.98 KB)
174_58872d0dbaf17.jpg 600X310 px
Posted on: 2017/1/24 10:31
Same seller, auction is for front coilover setup
http://page11.auctions.yahoo.co.jp/jp/auction/n198852462
Sunny Truck height adjustable coilovers late disk brakes hubs pillowball upper
camber angle adjustable
Short-stroke cartridge specifications.
Spring is 5 kg, lowdown, HKS-think it best to run attacked according to the stage and road conditions Sprint. Enjoy the great change
specializing in precision welding to ensure sufficient strength
ride quality is good I think
Barrier impact fewer depending on the hardness of the leaf spring and the long drive is fun
* Coilover installation Is the bolt-on
* Do not need to replace the knuckle arm
* Enlarging the pillow ball upper mounting holes need not
short stroke cartridge. Genuine comparison 160 mm shorter stroke short cartridge uses Stroke of cartridges 10 0 mm # include
Height adjustment screw is 160 mm (Picture 3)
* Left: lowered the height adjustment ring nut 180 mm low
* Right: raised the ride height adjustment ring nut 50 mm low
* OE strut is for comparison, not included in auction
純正比較㊧180mmショート㊨50mmショート
NOTE: Are committed to dealing with antisocial forces to eliminate the unfair intervention of anti-social forces and cooperation with specialized agencies
jpg  1 struts with disc brakes.jpg (33.81 KB)
174_588733182de9d.jpg 450X600 px
jpg  2 short strut kit.jpg (39.49 KB)
174_58873322024f1.jpg 600X450 px
jpg  3 comparison.jpg (30.37 KB)
174_58873329bcdff.jpg 600X450 px
Posted on: 2017/1/24 10:57
From RSA
will the willwood discs work with the above setup --cos this is nice plain and simple
Posted on: 2017/1/24 16:45
It's a standard 1200 disc brake strut (big stub axle), so any Wilwood that works with that is compatible
Posted on: 2017/1/24 23:59
