Carb model ID
From Sydney, NSW
Hi further to a previous conversation on here I was hoping to help get an ID on a carb. I'm after the specific model number if possible as I'd like to give it a once over and would prefer I had a rebuild kit in the garage for it.
Thanks very much
Posted on: 2017/3/7 20:01
Re: Carb model ID
Hitachi D carburetor as used on all A-series engines
It's the new improved DCR306. Here are the two biggest clues
jpg  IMG_20170214_085803.jpg (30.94 KB)
174_58bf26a9eb102.jpg 480X320 px
jpg  IMG_20170215_080231.jpg (41.33 KB)
174_58bf26b05e7a4.jpg 480X480 px
Posted on: 2017/3/7 21:41
Re: Carb model ID
From Sydney, NSW
So would there be any changes needed to it to get it spec'd right for an a15 and what do you usually do about servicing the vacuum secondary?
Thanks David always appreciate your help
Posted on: 2017/3/7 23:56
Re: Carb model ID
From Sydney, NSW
Would you recommend running this or a Weber 32/36 on a smooth mild daily?
Posted on: 2017/3/8 0:01
Re: Carb model ID
It is usually an A15 carburetor. It should run fine as-is. Servicing the vacuum secondary is done with the carburetor kit instructions
Hitachi DC carburetor runs much smoother than Weber 32/36, but the Weber makes more power over 5000 RPM
Posted on: 2017/3/8 2:20
Re: Carb model ID
Or possibly it's the Hitachi DCF-306, per the repair manual
What are the numbers in the carburetor throats?
Posted on: 2017/3/8 4:04
Re: Carb model ID
From Biloela, Sunshine State
Hey DD. If the Weber makes more power over 5000rpm, what is the margin on that? As in how much more could it make? (Mild engine, like: pistons, cam, valves, small bore out)
Posted on: 2017/3/9 3:10
Re: Carb model ID
Well instead of 85 HP @ the engine with the stock carburetor, a slightly warmed over engine might make 92 HP with the 32/36
Posted on: 2017/3/9 4:12
