« 1 (2)
Re: L,series
they are Bs 34,s Mikunis ... My Question Is What is the Best L,Series for them
L14. They are a little small for L-series engine (Datsun fitted 38mm twin carburetors to the L14/L16/L18). Nissan fitted BS32 to the A10 (1000 cc) engine
As I Have Stanza Struts in Now I thought the Extra Weight cloud bring Down the Front end....
Stanza struts on a 1200 won't necessarily affect the height of the car -- but the springs you have fitted will. If you have the stock (long) Stanza springs, lower the spring cup an appropriate amount. If the car sits 1" too high, lower the spring perch 1". Also note that King Springs sell the same unit (KDFL-17) for Stanza and 1200, and they will lower a 1200 approximately 30mm
I wouldn't mind a bit more Hp The Guy I got my carbs of said these might only get 100hp that's not much Hay
100hp is a lot compared to 69hp. But yes, BS34s made 90hp on the 1980 Suzuki GS1000, and made 102hp on the 1981 Kawasaki KZ1000. 100hp is a healthy A14 (stock A14 is 80hp) and requires high RPM camshaft and head work. L16 made 96hp with factory single carburetor, so fitting BS34s to an L16 won't increase the HP very much, but might improve the driveability & throttle response (smoothness)
Posted on: 2017/3/30 6:41
Re: L,series
get a GX cam or cam capable of 90-100hp for your A14, lectric dizzie
if you dont have one yet, shave the head if it needs more comp and if
its a h75 head instead of a h89? use efi setup if cam is big or 34mm carbs
with good headers/exhaust good economy, good hp at revs when you need it
L series gives you a 5 speed but gives much more torque even with 100hp.
Posted on: 2017/4/1 7:33
« 1 (2)
