« 1 (2) 3 »
Re: Datsun 1200 Brake Hard Lines
yes, Datsun 1200 brake lines are 3/16". Do not use copper, it requires double-flared high-pressure steel line. Cunifer steel or poly-coated steel for corrosion resistance
What we usually do in my country is buy a pre-flared line (say 48" long) and bend it to suit. Alternatively you can buy stock tubing, cut to length and then use a double-flaring tool to add the fittings (3/8" fitting on one end and M10 fitting on the other end)
Posted on: 2017/4/29 19:54
From Lisbon
Thanks for your help, that i was thinking, cooper is not good enough to high pressure
Its diicult obtain an article like the following
http://www.ebay.co.uk/itm/AeroFlow-Co ... h-Roll-7-6M-/152089241104
I will get an used brake line or waiting to re-listing on ebay or discover a shop who sells steel brake hard line
Many thanks for your cooperation
Luis
Posted on: 2017/4/29 23:12
From Lisbon
i Will install 2 of this reservoirs with 0.12 liter each of capacity. What do you think? It is the oil capacity enough?
http://www.ebay.com/itm/Aluminium-Liq ... :4b0AAOSwU9xURZn5&vxp=mtr
Posted on: 2017/4/30 19:21
From Lisbon
i Cant find material to make hard brakes lines with stainless steel
i only find cooper and material like the link
http://www.ebay.co.uk/itm/25-ft-3-16- ... 5d1392:g:BJgAAOSwZQRYgkgk
Please let me know where i cand find it. Some people told me to make with inox?
Please let me know thwe best choice to make the hardlines in my Datsun
Thanks
Luis
Posted on: 2017/5/4 17:54
Stainless steel is not used. Datsun uses either cunifer (a special copper-nickel alloy) or poly-coated steel
In other words, standard brake line material
Posted on: 2017/5/5 5:22
From Lisbon
Many Thanks
Its something like that? Or advice the best material on e-bay
http://www.ebay.co.uk/itm/Copper-Nick ... 4b09fd:g:usMAAOSwt5hYiPG3
In United Kingdom i can find it on e-bay
Please let me know and i will replace most of my brake car hard lines
Posted on: 2017/5/5 9:30
Edited by Luigi on 2017/5/5 17:56:22
From Lisbon
This item is perfefect for the job? I s is ressistant?
http://www.ebay.co.uk/itm/CUPRO-NICKE ... 380923:g:RkUAAOxyDEVSam68
Posted on: 2017/5/5 22:27
Have you asked at your local auto parts store? They are the same brake lines as used by Ford, Honda, etc.
Posted on: 2017/5/6 8:55
From Lisbon
No! i will buy it through ebay and i will need your help to choose the best choice. Im confused some people say its better stainless steel (because with vibration dont its better and dont break) other KUNIFER COOPER
I really dont know what to do, please let me know
Thanks
Luis
Posted on: 2017/5/6 13:35
I have never heard of stainless steel (inox) being used
Nissan used Cunifer lines
Posted on: 2017/5/7 4:13
« 1 (2) 3 »
