« 1 2 3 (4) 5 »
Re: EFI Manifold
From Zimbabwe
These manifolds are the most affordable I've seen.
Posted on: 2017/5/2 15:21
No skool like the old skool
Re: EFI Manifold
From Mordialloc Victoria 3195
knew that price of 30 Euros was too good to be true :(
dp
Posted on: 2017/5/5 5:56
keep it simple
Re: EFI Manifold
From Lyngby, Denmark
I will still be making a couple of sets soon.
But a question for those of you that is still interested. Should there be a flat mating surface instead of the tubular?
That would make it possible to bolt a plate of choice?
Just thought of it, as it would make it easier to adapt to custom solutions of throttle control.
Posted on: 2017/5/5 7:33
Re: EFI Manifold
great price and product but how much for the roller barrels!
I think most would be happy with normal bike itbs that probably
perform 2% less overall than that barrel setup and weigh less also.
Posted on: 2017/5/5 8:01
Re: EFI Manifold
The roller barrels would be around 600 euro... I think.
I have made an adaptor to suit Toyota RSI throttles, don't know it they are same dimensions as golf 20V ITB's. Is that something wanted by the masses? Price around 175 a set.
Posted on: 2017/5/5 12:10
Re: EFI Manifold
From Zimbabwe
In South Africa RSI throttle bodies are popular and used alot by VW guys on their Golfs. I don't know how other guys feel about then but I have a set that Im planning on using on my A15.
Posted on: 2017/5/5 13:50
Re: EFI Manifold
From Zimbabwe
Posted on: 2017/5/5 13:51
Re: EFI Manifold
I'm still intersted but only one set - at that price could a request be put in to
make them oval port with a flange as you suggested ? I think this would be the most popular ?
dp
Posted on: 2017/5/5 22:46
keep it simple
Re: EFI Manifold
They have arrived!
Fitment is perfect and requires a small port job to match the port, just as I intended.
Cheers, Toby
Posted on: 2017/6/11 18:16
Re: EFI Manifold
Posted on: 2017/6/11 18:20
« 1 2 3 (4) 5 »
