« 1 (2)
Re: nissan reliability after 5 years of its first electric vehicle
You can have a perfectly good battery (100% Capacity, for example a new car) and still have it needing a charge after driving a hundred miles
So there are two gauges ... for buying a used Leaf, the 2nd gauge is the important one
Posted on: 2017/5/12 6:00
So the state of charge is just deceiving in the graphic form
as its best to look just at the range after a full charge?
Also whats the left side gauge is that the regen?
Posted on: 2017/5/12 8:12
The state of charge and the capacity have little to do with each other
SOC: How charged the battery is (fully charged vs needs charging)
Capacity: How good the battery is (like-new vs worn out)
Posted on: 2017/5/12 8:49
DD so the one I posted on the first pic
is down 2 bars on capacity?
Looks like it is down 3-bars, in other words, battery is getting worn out. As I recall when I researched a few months ago, most of the oldest leafs in USA are only down 1 or 2 bars
Posted on: 2017/5/12 8:54
You can look at the range any time. At full charge (100% SOC), you get max range. At needing charge, there are less miles/kilos you can drive until it requires a re-charge
Looks like battery temperature???
Posted on: 2017/5/12 9:02
Im still not fitting into the party :(
so whats the best way to tell if the battery
has lost some of its original virility
by looking at the small bars on the far right?
Posted on: 2017/5/13 0:15
Yes, the bars on the far right are a direct gauge of virility of the battery. Wouldn't it be nice if all batteries had this feature?
Posted on: 2017/5/13 5:14
nicer if the had a cutout to protect them too
on these cheaper Leaf's I can see they are abuse
rentals where no care was given for charge needs
Nissan should really have a built in guidance to
nearest charge station before batts are compromised
Posted on: 2017/5/14 3:43
« 1 (2)
