Wanted 1200 coupe disc hub.
I'm after a hub to suit the imported 1200 coupe or 120Y coupe. I believe the imported Sunny coupe also had them. They run smaller bearings than the locally made ones. I'm in Sydney so closer to here would be preferable. Thanks
Posted on: 2017/5/21 9:48
Re: Wanted 1200 coupe disc hub.
1200 coupes and early 120Y have the larger bearings. Late 120Y has the smaller bearings
LARGE BEARING/SMALL STUB AXLE
* B110
* 120Y 1973-1975
SMALL BEARING/LARGE STUB AXLE
* 120Y 1976-1978
Posted on: 2017/5/21 11:38
Not here in oz. They were imported from Japan whereas the sedans etc were locally made. The coupes here had the small bearings.
Posted on: 2017/5/21 11:58
Quite a regular
From Sutherland Shire
I have the whole front end out of my coupe with struts, brakes, lines, arms etc. Aussie delivered tho. located Sydney.
Posted on: 2017/5/22 7:40
1972 1200 Coupe
SR20DE
R31 Diff
S14 Front End
PM sent
Posted on: 2017/5/22 23:52
