Fuel Pump is leaking fuel
From Sri Lanka
Hi Guys
After a little longer time, i recently changed my filters and contact point on my car it was running smooth, yesterday i had a highway tour , it was running great but sometimes when i am about to stop the car it stalls not always too, but it idles perfect, after coming home i checked it and found fuel pump was leaking fuel from diaphragm area, so need to replace the packing around and also found my fuel pump arm was worn out a little, i remember i filled it few months back with bronze it seems it warns out fast is there any other way to fill it to stay longer without getting worn out so soon ?
thanks
regards
sumith
Posted on: 2017/5/23 4:23
Re: Fuel Pump is leaking fuel
Yes, I've had leaks before. Two different causes:
* If fuel is leaking around the top cover, it's just a packing (gasket) issue. Tightening the screws usually fixes it
* If fuel runs out near the pivot pin, or leaks near the packing with the engine block, the diaphragm that pumps the fuel has a small leak in it, letting fuel to the back side. Putting a new packing in just redirects the leak, now it's leaking into the engine oil pan ...
Which brass piece are you asking about?
Posted on: 2017/5/23 7:06
From Sri Lanka
Hi DD
Actually fuel is leaking out from bottom packing which is going outside of the car not into the engine side , In this image what i mean is part no 9 as the ARM (the piece which touches the engine shaft from inside)
thanks
regards
sumith
Posted on: 2017/5/23 7:22
