Manifold Gasket Sealant - yay or nay
Are people using a sealant for the manifold gasket?. How about on the exhaust manifold to exhaust? I'm using the factory metal gaskets.
Posted on: 2017/7/11 8:56
Re: Manifold Gasket Sealant - yay or nay
From Townsville, Qld
For any gaskets on the head or block I've been using aviation sealant, for exhaust flanges I use high temp copper grease
Posted on: 2017/7/11 9:08
Posted on: 2017/7/11 9:13
Sure you can use sealant. Or not. I never do, and have never had a leak
Posted on: 2017/7/11 9:15
I have always used either Loctite Master Gasket on the inlet and high temp rtv on the exhaust although lately been using the rtv on both.
I was told some time ago by a very good old school rally car builder that if you use a gasket and it blows you are out- rtv doesn't do that. The worst you may get would be a pinhole size leak.
Good preparation is no doubt the key to all this.
Interestingly enough my engine builder who specializes in Cosworth BDA engines only uses rtv ( silicon )on both manifolds and the finish record of cars that he prepares speaks for itself.
Cheers
Dave
Posted on: 2017/7/11 21:54
Misleading. Are you all applying sealant between the manifold and gasket or between the gasket and head? Or both?
Posted on: 2017/7/12 3:32
Between the manifolds and the head- in other words no gasket
Posted on: 2017/7/12 4:03
RTV is a type of gasket. Often called "gasket maker". Nissan calls it "liquid gasket" and uses it on some engines including SR20
Posted on: 2017/7/12 5:45
