Suction Pipe, how to remove?
I have a rebuilt engine, but it has a cracked suction pipe that leaks badly. I have a brand new suction pipe.
I've tried putting vice grip on it a have whacked as hard as I can but it does not want to budge.
Any other tricks to get it out? Cut it and use some kind of bearing puller and slide hammer? Heat?
Posted on: 2017/7/25 9:14
Re: Suction Pipe, how to remove?
I have removed several. Using vice grips, tap moderately with hammer on both sides to rock the pipe back & forth and eventually out
Posted on: 2017/7/25 9:40
Ok thanks DD. Will persevere patiently!
Posted on: 2017/7/25 9:43
