FS Cherry E10 model head - very similar to the A12GX head (I believe)
Quite a regular
From Bendigo
Good evening
I believe,searching through this web site, that I have a Cherry E10 model head.
If I am wrong please let me know.
I do not know what they are worth but if it is a Early A12T Head then I suspect it is worth a bit.
If your interested please send me an Expression of Interest via this site.
Thank you for your time.
jpg  Datsun Head 1.jpg (94.68 KB)
15625_597dd61783265.jpg 390X520 px
jpg  Datsun Head 2.jpg (103.83 KB)
15625_597dd65ccc564.jpg 390X520 px
jpg  Datsun Head 3.jpg (105.86 KB)
15625_597dd66ccc9b4.jpg 390X520 px
Posted on: 2017/7/30 13:52
Re: FS Cherry E10 model head - very similar to the A12GX head (I believe)
From gold coast QLD australia
dd may be able to clarify your query.
I didnt think GX heads had water galleries under the ports???
Posted on: 2017/7/31 10:24
GO RACING,GO HARD OR GO HOME!!
SLY OLD FOX..................
The four holes under the inlet ports transfered hot coolant into the water jacket under the inlet manifold.
The GX was a street model in a country where it snows, so it is necessary to ensure complete vaporisation of the liquid fuel by the simple expedient of manifold heating.
Regular models do it by using the exhaust manifolad hot spot under the carb.
Posted on: 2017/7/31 10:43
Love your Datsun.
Treat it well.
From Christchurch NZ
From my memory of looking into this on wiki the "gx" head and A12T heads had different nissan part numbers in the catalogs but measure up to be identical castings, ports, valves etc.
Posted on: 2017/8/1 2:01
Yes, Dodgeman is the expert on the GX. I might add that there are two A12T engines
* early A12T is like the A12GX
* late A12T w/o oil passage hole, for 1974-up blocks
although early A12T and GX castings look identical there may be some difference we haven't noticed. Or maybe those Prince engineers just had to use their own part number instead of the Datsun part number
Posted on: 2017/8/1 4:54
Dodgeman is a real life version of the complete Nissan 1000 and 1200 parts catalog :)
Posted on: 2017/8/4 0:27
Quite a regular
From Bendigo
Thanks for the the comments. What type of $$$$ are these heads worth? Thank you
Posted on: 2017/8/5 8:24
From WEST AUSTRALIA
EDIT
Posted on: 2017/8/5 9:11
Edited by KULH on 2018/3/14 0:11:25
From WEST AUSTRALIA
EDIT
Posted on: 2017/8/5 9:22
Edited by KULH on 2018/3/14 0:11:04
From WEST AUSTRALIA
EDIT
Posted on: 2017/8/5 9:26
Edited by KULH on 2018/3/14 0:10:28
