CA18det injectors
From Nyngan, nsw Australia
whats the danger in putting slightly bigger CC's injectors in a standard CA,
pretty sure originals 330cc I think, whats the next size up?
Posted on: 2017/9/24 1:51
living is good,.....
Re: CA18det injectors
CA18DET -- in Japan -- came with the white injectors 16600-56E00 or variation (16600-56E01, 16600-56E05, etc)
370cc
Next step up in Nissan factory injectors is the Yellow 444cc SR20DET injector, which is a big step up
Posted on: 2017/9/24 3:46
From Adelaide
Going too big can give you trouble at idle. It gets to the point where you can't get a short enough squirt for idle fuel mix. How big is too big, I don't know. Depends on many things. Someone else may have experience with a set up like yours.
Posted on: 2017/9/24 11:08
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From gold coast QLD.
Does,nt matter how big the injectors are as long as the engine is correctly tuned on the dyno after installation,otherwise you are wasting your time and dollars
Posted on: 2017/9/25 0:58
From Creswell, Oregon USA
Are you running a Haltech or Mega SQRT?
Posted on: 2017/9/26 20:58
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
motor and computer completely stocko, while engine is idling its fine once the revs are up its missing, ive changed coils & plugs and still there, also done test on both fuel pumps there good, so thinking next thing is injectors, starting to #OOPS# me
Posted on: 2017/9/26 22:10
As previously mentioned, if you fit bigger injectors it will require an ECM retune. Without the retune it'll run very rich -- I'd guess it would start but then stall as it warms up. Maybe it will run long enough to get into closed-loop mode and start running correctly
You can test your injectors before shelling out coin for new ones
Also do a fuel volume test, especially when it idles OK but doesn't run right when driving
Have you examine the fuel pressure after the revs come up? Sometime the starting & idle pressure are OK, but not the full pressure
Posted on: 2017/9/27 5:38
