Browsing this Thread:
1 Anonymous Users
A15 and Bluebird diff |
Not too shy to talk
Just checkin on what a reasonable price should be for a low milage import A15. There is a TRX Bluebird going for bits. Does that axle have discs and are there many options on the ratios and can I get a LSD diff centre for that axle. Will it bolt up reasonably easily or not? thanks all mely
Posted on: 2001/11/23 12:24
Re: A15 and Bluebird diff |
Mely, when i was hunting round for an LSD, i too thought about the bluebird option. trouble is, the blubirds only came with an LSD on very rare nizmo models. Jeff Taylore, of JTS Performance, can hunt one down for you. i asked him myself if he was able to get them and he said he could but i'd be paying for it. somewhere along the lines of $1500. good investment for a good ratio LSD to suit a ute housing. i think those blubrid diffs do come with disc brakes and they more or less bolt straight on as the axles are the same size and the bolt spacing on the acking plate is the same as the ute diff. just a matter of working out what your gonna do with the handbrake thats all. as for an A15, from an importer, somewhere around 6-700. if they can get hold of an A15. most of them can only get A14's. Justin
Posted on: 2001/11/23 8:10
Not too shy to talk
cheers justin there is an A15 in the trader for $300 so I think I will go and have a peek at that this week sometime. thanks mate mely
Posted on: 2001/11/23 10:34
