BOTTOM BREATHER
From Albury
Quick question.
Do we need the bottom breather on the A series motor or can it be capped off and only use the rocker cover breather ??
Thanks
Posted on: 2017/10/3 2:58
Re: BOTTOM BREATHER
From gold coast QLD.
Bob,it,s there to remove any crank case pressure,if it cant get away it'll go out past the rings..... or blow out the front or rear seals
Posted on: 2017/10/3 4:36
Re: BOTTOM BREATHER
the pressure is mostly due to blow-by and crank rotation, so it's mostly in the bottom half. The early A-series had the top half capped off with the above-the-head space vented via the head's oil drain holes, then to the bottom breather tube
Posted on: 2017/10/3 5:11
Re: BOTTOM BREATHER
From Launceston TAS
im about to fit a single dcoe weber to my a15,does the crankcase breather still have to go to the inlet manifold? or can it just vent to the atmosphere? cheers Barry!
Posted on: 2017/10/3 20:00
Re: BOTTOM BREATHER
It can vent to atmosphere, but then it doesn't work as well and you might smell the fumes sometimes
Posted on: 2017/10/4 9:09
Re: BOTTOM BREATHER
From Launceston TAS
ok thanks,so ill need to make sure the thred in the new manifold is the same and replumb it!
Posted on: 2017/10/4 18:56
Re: BOTTOM BREATHER
From Central coast NSW
If you don't plumb it to the inlet it won't actively draw the blow by from the crank case in turn contaminating the oil sooner as long as you change the oil regularly it won't matter you can just put a small pod filter on it...
Posted on: 2017/10/4 20:10
