R31 Diff question
From Sydney, Australia
Hi Guys,
Can I use my H165 upper and lower U-Bolt holder with my R31 diff?
If not, then where can I get it from?
Kind regards,
Ron
jpg  ubolts.JPG (35.04 KB)
18758_59e543b7ce00a.jpg 352X360 px
Posted on: 2017/10/17 0:41
Re: R31 Diff question
Those parts are too small for the Borg Warner 78
* No need for the top part, just let the bolts wrap around the axle tube. Maybe you can use an R31 bump stop
* Use the BW bottom plate as it will be the correct size for the U-bolts. You may weld a shock mount stud to the plate in the same location as the stud on the Datsun plate
Posted on: 2017/10/17 10:04
From Perth
BW only came as 4 link not leaf in R31
You'll have to take a look at Commodore or Falcon leaf setups to see if you can adapt those parts
Posted on: 2017/10/17 11:52
Thanks #dattoman_1000,
Will look into that.
Posted on: 2017/10/17 12:24
I used Holden hq leaf saddles in my coupe
Posted on: 2017/10/19 7:05
Car free
From Adelaide
HQ was the first coil spring rear end in a Holden. HK/T/G and prior were leaf spring rear ends.
Posted on: 2017/10/20 20:16
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Correct sorry they are hg shock plates, I have a spare set here $75 plus post
Posted on: 2017/10/21 10:19
Car free
Quite a regular
From Sutherland Shire
I needed to do this as well. Was going to modify my 1200 coupe plates. But cheers for the idea. just picked up a set off ebay!
Posted on: 2017/10/24 0:23
1972 1200 Coupe
SR20DE
R31 Diff
S14 Front End
