Browsing this Thread:   3 Anonymous Users
A12 turbo
Anyone know where i can get a cometic mls gasket for a12
Thanks
Posted on: 2017/10/29 10:04
Re: A12 turbo
Right from http://www.cometic.com . They also have dealers in many countries listed on the web site
The stock A12 gasket will only handle 15 psi boost, so cometic is the way to go
Posted on: 2017/10/29 17:55
Re: A12 turbo
From Mordialloc Victoria 3195
I'm also looking for boosted head gasket options but couldn't find A series head gasket on there website
Posted on: 2017/10/29 21:21
keep it simple
Re: A12 turbo
If you're looking for MLS gasket, Bprojects sells them for A14/A15
For copper gasket, Cometic custom order will do
Posted on: 2017/10/29 22:56
Re: A12 turbo
From Melbourne Vic
i dont think an MLS is necessary unless youre running big boost. head studs are definitely a good idea though.
ziggy, have you had dramas with the a15 efi turbo?
Posted on: 2017/10/30 0:03
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: A12 turbo
Hey leigh - No problem on the turbo ute as it runs 10psi.
Im getting parts together to build a 15psi+ version to go in the Clubman 7
so I'm just upping everything I did on the last one
dp
Posted on: 2017/10/30 0:30
keep it simple
Re: A12 turbo
I wont be running more than 10 psi. Where can i buy stronger head studs?
Posted on: 2017/10/30 10:07
Re: A12 turbo
Posted on: 2017/10/30 20:37
keep it simple
Re: A12 turbo
Thanks guys
Posted on: 2017/10/31 8:55
Re: A12 turbo
Also are all a12 engines the same? I got one from a 120y to rebuild
Posted on: 2017/10/31 11:04
