HEI ignition upgrade
From Sydney, Australia
Hi All
Wondering if anyone has done this in there 1200?
I've been looking for an option that isn't huge $$$
Using a reluctance pickup dizzy and a low primary resistance, transformer type coil, to get a good whack of spark to the plugs
Just did some googling to find this article
http://dtec.net.au/High%20Energy%20Ignition%20Upgrade.htm
I will be doing it myself, seems fairly straight forward, with easy to get parts
Hope it interests others.
Any thoughts or advice welcome
Cheers
Posted on: 2017/11/11 11:12
Re: HEI ignition upgrade
From Adelaide
There's a few good suggestions in the Tech Wiki on this. A whole page on it: http://datsun1200.com/modules/mediawi ... title=Electronic_Ignition
Initially I used a Jaycar HEI kit, mainly because when I bought the car it had a low ohm coil on the stock system, so the coil cooked and the car broke down. Now I've got the Ford EDIS setup on there. If I did it again I'd just use the wasted spark option on the Megasquirt.
Posted on: 2017/11/11 20:01
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
The DTEC method looks very do-able. But also consider using a GM HEI module (new or used). It's almost exactly the same thing -- see GM HEI
This works with Datsun and Nissan reluctance (EI) distributors. But if you already have the stock Nissan EI unit, it's even more reliable than the GM unit, and just as High Energy
Make sure you use a high-energy coil. The standard 12V low energy coil may be used if you retain the ballast resistor
* remove ballast resistor and use 12V high energy coil (like the Bluebird EI coil)
OR
* keep the ballast resistor and use 12V low energy coil (like standard 1200 coil)
Either one will work with HEI module
jpg  GM HEI on Datsun.jpg (36.16 KB)
174_5a078afe9703b.jpg 480X360 px
jpg  HEI wiring with high-enery coil.jpg (24.08 KB)
174_5a078dedb1df2.jpg 560X352 px
Posted on: 2017/11/11 23:42
I should have said all that applies to the Bosch 021 modules as well. Even the wiring diagram is the same
Bosch 021 is very common here in USA and also I understand in Australia, even can be found on Ford vehicles (many 1981-1985 V8s, for example). For reliability mount it on a heat sink with thermal paste. It will last longer than when mounted directly on the distributor like it was in the Nissan Bluebird. Some bolt it to the strut housing on a thin aluminum plate
Posted on: 2017/11/12 6:44
Hi guys
Thanks for the replies and links
I read the GM HEI one
Where I got the idea from actually, love the tech wiki 👍
The reason being
I have a Chinese made, (EBay) dizzy
It has a module, but unknown what module it is
Or what a low resistance coil might do to it.
I know the GM ones will take the extra current and the internal transistors do the job of switching
Anyone had and experience running a higher power coil on the Chinese dizzys?
Reliable?? Or did it go up in smoke ?
Posted on: 2017/11/12 7:36
If the Chinese-made dizzy module looks like this:
... that's the type that is for high-energy coil. Now the quality may vary depending on the maker of the module, but at least one of the Chinese makers is good. Does it have a brand name or number on the module?
Posted on: 2017/11/13 4:25
Hi D
I'll attach a photo
It has a module inside
The number I believe probably refers to a date of manufacture maybe ?
Says 2011 07 16
It's grounded to the dizzy body with the two mounting screws.
However, not sure if its going to like switching a low primary resistance coil
Planning on using a Bosch transistor HEC715
I'm building an A14/15 for my ute now.
So won't be testing until the motor is back together and in the car.
I figure if it burns out the module in the dizzy.
I'll just use an 021 module that will do the job.
They are about $80 brand new
Posted on: 2017/11/13 8:25
From Little Rock, AR
Does a stock USDM 1981 B310/210 use a high energy coil from the factory? I'm thinking so since it's electronic ignition and has no ballast resistor but want to make sure before I try to install a MSD 6AL amplifier in the near future...
Posted on: 2017/11/14 15:18
Yes, all USA B310 is high energy. Also 1978 B210. 1975-1977 B210 was low energy though some used a high-energy coil along with a resistor because the early modules couldn't handle high amps
Posted on: 2017/11/14 22:50
