Aircon set
GENUINE 1200 air conditioning set, factory installation components
For sale now, current bid $295
https://page.auctions.yahoo.co.jp/jp/auction/x514422877
https://youtu.be/bZY7TZafSTw
Cooler set removed from the sunny truck is second hand goods
* Indoor unit (hanging mount type on the front passenger side)
* Indoor Unit Mounting Portion Part 1
* Cooler compressor
* Compressor mounting bracket (with tensioner) fits 1974-up A-series engines
* 2 low pressure and high pressure parts and piping
* Condensor × 2 (with electric fan on one)
* Liquid tank, wiring harness
NOT INCLUDED
* W type clamp lee is not included
* V-belt not included
* Double-groove crankshaft pulley
jpg  1979-up 1200 aircon.JPG (130.77 KB)
174_5a1a572dbd2d8.jpg 640X480 px
jpg  bZY7TZafSTw.jpg (36.08 KB)
174_5a1a5799dd0f8.jpg 798X399 px
Posted on: 2017/11/26 5:56
Re: Aircon set
This auction has dozens of photos which may be useful for someone wanting to source their own parts. Of course you can buy a NEW set but if you have good wrecking yards nearby why not use them?
This set was designed for R12 freon, but can use the (now out of date) R134A, which was common from about 1994-2016. So no worries about getting refrigerant
It uses a modern swash-plate type compressor, and similar/same units may be in your local scrapyards on other Japanese cars
Posted on: 2017/11/26 6:35
A12 aircon Compressor Bracket
The factory 1200 bracket (from 1979-up) fits the modern type compressor. There are some newer compressors that are smaller, but are generally of the same type
It bolts to the manifold side of the engine. So it won't fit a 1970-1973 A12, but you can make your own compressor brackets
* Bracket 593017 6100 w/low-mount tensioner
* Differs from B310 brackets
Use with common G16 Crankshaft Pulley (1979-) and 814mm v-belt
jpg  00_00 (37) engine side.JPG (36.77 KB)
174_5a1a65a499d48.jpg 516X387 px
jpg  00_00 (38).JPG (112.07 KB)
174_5a1a65accb013.jpg 640X480 px
jpg  00_00 (39) tensioner pulley.JPG (86.15 KB)
174_5a1a65b88322b.jpg 640X480 px
jpg  00_00 (40).JPG (85.03 KB)
174_5a1a65bfb6b6b.jpg 640X480 px
jpg  00_00 (41).JPG (101.95 KB)
174_5a1a65ce1162b.jpg 640X480 px
jpg  00_00 (42).JPG (111.29 KB)
174_5a1a65d42b54e.jpg 640X480 px
jpg  00_00 (43) outside.JPG (46.29 KB)
174_5a1a65dd89ea6.jpg 600X450 px
jpg  00_00 (44) casting number.JPG (147.71 KB)
174_5a1a65e48f697.jpg 640X480 px
Posted on: 2017/11/26 6:59
aircon Compressor
Compressor is the modern style swash plate (radial) design. It is a KKDC (Diesel Kiki) unit. These were Nissan factory parts
Compressor has low-side and high-side lines and a wire for the electric clutch (same as new compressors). It is marked R12 but can take R134A if the appropriate oil is introduced to the system (bolt everything up, evacuate the system, add R134A and oil)
* Clutch # 509631
* Compressor # 509615 3924
* Type: DKS (Diesel Kiki Swash)
* Part 509630
jpg  00_00 (48).JPG (97.41 KB)
174_5a1a7d9468046.jpg 640X480 px
jpg  00_00 (49).JPG (102.63 KB)
174_5a1a7da31dcbc.jpg 640X480 px
jpg  00_00 (50).JPG (109.42 KB)
174_5a1a7dac69a3b.jpg 640X480 px
jpg  00_00 (51).JPG (115.51 KB)
174_5a1a7e316545b.jpg 640X480 px
jpg  00_00 (52).JPG (105.39 KB)
174_5a1a7e3f27d18.jpg 640X480 px
jpg  00_00 (53).JPG (97.51 KB)
174_5a1a7e47d50dc.jpg 640X480 px
jpg  00_00 (54).JPG (104.27 KB)
174_5a1a7e4e67e1b.jpg 640X480 px
jpg  00_00 (55).JPG (127.39 KB)
174_5a1a7e57b8b98.jpg 640X480 px
jpg  00_00 (56).JPG (94.28 KB)
174_5a1a7e5f2cc2c.jpg 640X480 px
jpg  00_00 (57).JPG (89.18 KB)
174_5a1a7e6837302.jpg 640X480 px
jpg  00_00 (58).JPG (130.63 KB)
174_5a1a7e7ada3bb.jpg 640X480 px
Posted on: 2017/11/26 8:44
Condensors
The 1200 used twin condensors -- the radiator-like part of an aircon system. The cores are both 283 x 244 mm. The one to the side of the radiator uses an electric pusher fan
Unfamilia noticed that the Lancer CB uses a similar condenser, just wider. The brackets are removable so the condenser can be fitted easily
jpg  G27-30a_1280.jpg (141.94 KB)
174_5a1b57dc519a0.jpg 1280X730 px
jpg  00_00 (6) Twin 283 x 244 cores.JPG (128.27 KB)
174_5a1b59a1681e4.jpg 640X480 px
jpg  00_00 (7) Right Core fan.JPG (109.94 KB)
174_5a1b59a96d3c5.jpg 640X480 px
jpg  00_00 (8).JPG (110.12 KB)
174_5a1b59b0e66a7.jpg 640X480 px
jpg  00_00 (9).JPG (107.95 KB)
174_5a1b59b7efe5f.jpg 640X480 px
jpg  00_00 (10).JPG (109.00 KB)
174_5a1b59c11affc.jpg 640X480 px
jpg  00_00 (11).JPG (103.26 KB)
174_5a1b59c9f3c1d.jpg 640X480 px
jpg  00_00 (12).JPG (102.69 KB)
174_5a1b59d204759.jpg 640X480 px
jpg  00_00 (13) ~25mm core + ~65m fan.JPG (106.59 KB)
174_5a1b59ddcf496.jpg 640X480 px
jpg  00_00 (14).JPG (109.76 KB)
174_5a1b59ec38152.jpg 640X480 px
jpg  00_00 (15).JPG (103.55 KB)
174_5a1b59f28b8d7.jpg 640X480 px
jpg  00_00 (16).JPG (80.27 KB)
174_5a1b59fa5cc28.jpg 640X480 px
jpg  00_00 (17).JPG (128.50 KB)
174_5a1b5a0385068.jpg 640X480 px
jpg  00_00 (18).JPG (148.21 KB)
174_5a1b5a0f66985.jpg 640X480 px
jpg  00_00 (19).JPG (128.68 KB)
174_5a1b5a190dba8.jpg 640X480 px
jpg  00_00 (20).JPG (90.28 KB)
174_5a1b5a227bbf7.jpg 640X480 px
jpg  00_00 (21).JPG (136.77 KB)
174_5a1b5a2f91377.jpg 640X480 px
jpg  00_00 (22).JPG (109.15 KB)
174_5a1b5a3c4ac6f.jpg 640X480 px
jpg  00_00 (23) Right Condensor.JPG (101.78 KB)
174_5a1b5a4e814f3.jpg 640X480 px
jpg  00_00 (24).JPG (97.22 KB)
174_5a1b5a564a615.jpg 640X480 px
jpg  00_00 (25).JPG (126.31 KB)
174_5a1b5a61856e5.jpg 640X480 px
jpg  00_00 (26).JPG (133.73 KB)
174_5a1b5a72a6215.jpg 640X480 px
jpg  00_00 (27).JPG (93.10 KB)
174_5a1b5a7d9098d.jpg 640X480 px
jpg  00_00 (28).JPG (146.50 KB)
174_5a1b5a8515ddf.jpg 640X480 px
jpg  00_00 (29).JPG (120.02 KB)
174_5a1b5a8d43582.jpg 640X480 px
jpg  00_00 (30).JPG (156.08 KB)
174_5a1b5a9a6b0d8.jpg 640X480 px
jpg  00_00 (31).JPG (118.28 KB)
174_5a1b5aa241a77.jpg 640X480 px
jpg  00_00 (32).JPG (142.22 KB)
174_5a1b5aafdae86.jpg 640X480 px
Posted on: 2017/11/27 0:22
Re: Condensors
CONDENSOR layout
jpg  G27-30a2.jpg (50.08 KB)
174_5a1bbcee5ed64.jpg 722X540 px
jpg  G27-30a1.jpg (82.29 KB)
174_5a1bbcfe5784b.jpg 1024X692 px
Posted on: 2017/11/27 7:21
Re: pics of the compressor bracket
Here's more pics
jpg  n269163941.jpg (17.03 KB)
174_5c452c6591662.jpg 449X337 px
jpg  k194636243_1.jpg (24.64 KB)
174_5c452c6c82bd3.jpg 600X450 px
jpg  k194636243_2.jpg (25.41 KB)
174_5c452c733f62b.jpg 600X450 px
jpg  k194636243_3.jpg (20.13 KB)
174_5c452c7a6aa50.jpg 600X450 px
Posted on: 2019/1/21 2:20
matching double-belt pulley
This bracket is the most common one, always on sale on Yahoo. Used on Datsun 1200 1979-1994 JDM. it's a beauty -- no NVH here. With lightening holes but ribbed for strength. The only way it could be better is if it was light alloy instead of cast iron. Has integrated tensioner pulley
jpg  cb0.jpg (40.39 KB)
174_5c45a258b87d1.jpg 518X388 px
jpg  compressor mounting bolts.jpg (70.01 KB)
174_5c45a2674b862.jpg 500X375 px
jpg  cb1.jpg (25.57 KB)
174_5c45a26bd1247.jpg 600X450 px
jpg  cb2.jpg (22.12 KB)
174_5c45a273eae3b.jpg 600X450 px
jpg  cb3.jpg (28.85 KB)
174_5c45a278de62b.jpg 600X450 px
Posted on: 2019/1/21 10:46
Sanden compressor bracket
The bracket to replace the square York compressor (USA and AUS original equipment) with a modern lightweight Sanden compressor is $60 at Summit Racing
Since the block area where it bolts is basically flat, you could use the generic Sanden bracket with an adapter plate -- might be useful if you don't have a Aircon setup to begin with. Somehow you'd have to figure out how to fit and Adjuster idler pulley
New Compressor with bracket $195
jpg  Sanden compressor bracket (replaces york type) vta-15815-vub_xl.jpg (105.29 KB)
174_5c45a548354f8.jpg 1600X1218 px
jpg  CM_5H14_2400FC-1.jpg (44.63 KB)
174_5c45a5529a62a.jpg 570X480 px
Posted on: 2019/1/21 10:57
Aircon - YORK bracket
For square York compressor. Kinda heavy and antique looking but exactly period and used on all the muscle cars ....
jpg  1980 210 ac _.jpg (140.39 KB)
174_5cbac6634c1cc.jpg 768X1024 px
jpg  1980 210 ac bracket 11910-H9900 york type _.jpg (190.33 KB)
174_5cbac66ecc7e8.jpg 1202X1063 px
Posted on: 2019/4/20 8:15
