« 1 (2)
Re: Car Stalls I am going crazy now !!!
I've had those same symptoms in my 1200. In my case it was particles in the gasoline (petrol) that mostly affected the idle. Had this kind of problem about 4 times over the years
This solved it each time for me: Drain the Fuel Bowl . Although once it only made it better. Drained it again and a third time before it cleared all the contaminated petrol out
Posted on: 2017/12/30 6:02
From Brisbane
My suggestion after much thought is to find an
old chap in a country garage and tell him all
the symptoms and leave it with him for a week.
If it is an intermittent fault then a trained
technicians eye is needed.
Often a very small detail is overlooked and
much time is wasted.
As I said at the beginning this is just a suggestion
Posted on: 2017/12/30 9:54
From Sri Lanka
Hi Guys
As Suggested by few guys, I took my carburetor parts and soaked them on COCA COLA over night
they were pretty clean and clear dried them nicely and cleaned them with vacuum and fixed the carburetor back, and also adjusted my carburetor door by loosening small screws on the door shaft as for my eye it was not perfectly closing .
it sounds good for 2 days so far not stalling on idle not stalled on stop lights too , idles good on low rpm also, i will use it few more day and update the status
thanks
regards
sumith
Posted on: 2018/1/14 12:24
From Sri Lanka
Hi Guys
I went a tour about 60 Kms today, car sounds good no stalling on idle or traffic light but noticed that the idle was a little higher than normal specially when shifting gears from third to forth it used to rev more than usual
( it is noticed idle drops very slowly after releasing the gas pedal- i have changed accelerator cable but did not lubricate it yet do not know whether it affects the slow rpm down to normal when releasing the pedal ),
after the tour i put the idle rpm down more , it sounded very smooth and good on that rpm and idles normal without shaking and stalling
only thing it was a bit hard to start it, even though i pulled the choke cable it took little more turns and more time to start in the morning,
after the first start it started normal throughout the day(these days climate here is extremely colder than usual days).
thanks
regards
sumith
Posted on: 2018/1/18 14:44
From Sri Lanka
Hi Guys
After a another week more i drove it , sounds good and smooth and cool ,Elder Brother(b210) Younger Brother(b310),Booth looks happy about, Finally a 2L Bottle or COCA COLA Made my day
happy;thanks guys for all the support given from forum
thanks
regards
sumith
jpg  resized.jpg (76.17 KB)
10994_5a7049296ace9.jpg 480X640 px
jpg  coke.jpg (11.58 KB)
10994_5a7049318a645.jpg 259X194 px
Posted on: 2018/1/30 10:30
Worth celebrating!
Posted on: 2018/2/1 8:11
« 1 (2)
