Side Markers
North America 1200s were subject to Federal Motor Vehicle Safety Standard 108 so we received the beautiful and highly reflective phat side markers
wimpy side markers
improved Canada/USA side markers
In addition becase FMVSS did not require it at the time, they were non-blinking -- just parking lamps. Front and rear were required after 1970
enough talk. here's some photos
Okinawa 1973
Posted on: 2018/7/11 3:51
Re: Side Markers - FRONT AMBER
front side marker is same coupe and sedan - amber (orange) lens is required. But left and right differ for no discernable reason
R and L lens is the same. It is marked 'TOP' on both edges so can be turned over for correct bevel for the side (Lens is thicker at front edge matching the curvature so the fender)
jpg  TOP TOP.jpg (171.12 KB)
174_5b45742bcc2dd.jpg 1318X848 px
jpg  front amber R.jpg (152.48 KB)
174_5b4574580d799.jpg 1600X900 px
jpg  front amber L.jpg (152.91 KB)
174_5b457473219b7.jpg 1600X900 px
jpg  IKI 5003 JAPAN SAE P189 SAE A69 IKI 7007.jpg (153.22 KB)
174_5b457482c8950.jpg 1369X787 px
jpg  MADE IN JAPAN.jpg (32.60 KB)
174_5b45748b17d45.jpg 533X400 px
jpg  Packing.jpg (160.36 KB)
174_5b45749575cf7.jpg 1600X900 px
Posted on: 2018/7/11 4:08
Re: Side Markers - REAR RED
Rear differs coupe vs sedan. I cannot spot the difference
The lenses are marked same as fronts -- IKI 5003/IKI 7007 (ICHIKO was the company that sourced them for Nissan)
Also like the fronts, they are marked SAE P169/SAE A69 which it seems many north america lenses were (Ford, Chevy, Volkswagen, etc)
jpg  Rear side markers.jpg (143.35 KB)
174_5b457665bceb3.jpg 1471X884 px
jpg  Right Rear (reverse).jpg (154.65 KB)
174_5b45768174e63.jpg 1600X900 px
jpg  Right Rear packing.jpg (149.01 KB)
174_5b45768ba51f9.jpg 1600X900 px
jpg  Left Rear (reverse).jpg (149.54 KB)
174_5b4576a819cd9.jpg 1600X900 px
jpg  LR (reverse).jpg (137.86 KB)
174_5b4576afa50fc.jpg 1600X900 px
jpg  LR IKI 5003 IKI 7007.jpg (163.68 KB)
174_5b4576bc55c2b.jpg 1600X900 px
jpg  LR MADE IN JAPAN.jpg (161.06 KB)
174_5b4576c360f48.jpg 1600X900 px
jpg  LR SAE P169 SAE A69.jpg (138.54 KB)
174_5b4576d850c66.jpg 1600X900 px
jpg  LR TOP TOP.jpg (146.01 KB)
174_5b4576e3ce84d.jpg 1600X900 px
jpg  LR8.jpg (148.39 KB)
174_5b4576ea8cb1c.jpg 1600X900 px
jpg  LRA.jpg (122.94 KB)
174_5b4576f1e2e70.jpg 1600X900 px
Posted on: 2018/7/11 4:18
Re: Side Markers - SAE codes
Found a list of SAE lighting standards codes (SAE J759)
SAEPI69
SAE = Society of Automotive Engineers
P = Parking Lamps
I = Turn signal lamps
A = Reflex reflectors
69 = 1969
Although these don't have Turn Signals in them, perhaps it was considered. In any case the final NA side lamps are only parking lamps (no indicators/blinkers)
jpg  B110 side lamp housing SAEPIA69 IKI 5003 JAPAN.jpg (88.84 KB)
174_5b4587336916a.jpg 722X400 px
Posted on: 2018/7/11 5:27
Re: Side Markers - 620 pickup
USA/Canada Datsun 620 uses same lens & rim as 1200
* The front housing looks identical but has a different part number. Wiring even looks the same (bullet connectors)
* The rear housing is deeply angled so won't fit a 1200
USA 620 vs 1200
* lens & rim interchange
The packing (gasket) is marked FLH RRH implying it can be used on both Front LH and Rear RH, but the Datsun parts catalog shows a different number for each corner
jpg  Front side marker.jpg (118.07 KB)
174_5b45a3fb0f4d8.jpg 2592X1944 px
jpg  Front side marker (reverse).jpg (92.71 KB)
174_5b45a401b4494.jpg 2592X1944 px
jpg  FLH RRH.jpg (100.50 KB)
174_5b45a40db05f9.jpg 2592X1944 px
jpg  bevel.jpg (93.61 KB)
174_5b45a41885450.jpg 2592X1944 px
jpg  H19 lens.jpg (111.53 KB)
174_5b45a42716565.jpg 2592X1944 px
jpg  S171.jpg (96.96 KB)
174_5b45a4313ea76.jpg 2592X1944 px
174_5b45a43bc7c9c.jpg 2592X1944 px
jpg  SAE_PI69 SAE_A69.jpg (156.41 KB)
174_5b45a448b7019.jpg 2592X1944 px
Posted on: 2018/7/11 7:31
Edited by ddgonzal on 2025/3/22 20:48:16
Re: late JDM Side Markers
Sunny Truck -- at first -- used the same H10 side lamps as the sedan/wagon/coupe until March 1978
From April 1978 they used a G10 lamp with a black rim
jpg  IKI5002 .jpg (118.99 KB)
174_5bc7e7167e6e9.jpg 1280X813 px
jpg  IKI5002 a .jpg (157.53 KB)
174_5bc7e730c959d.jpg 1280X960 px
jpg  IKI5002 back .jpg (165.99 KB)
174_5bc7e75199728.jpg 1600X1200 px
jpg  IKI5002 wiring .jpg (129.93 KB)
174_5bc7e75b3811a.jpg 1280X960 px
Posted on: 2018/10/18 2:49
Re: Side Markers - FRONT AMBER North America
Unlike the multitude of "1200" lamps on eBay, which are actually B210 lamps, 1200 lamps have
* two bullet-connector wiring
* rectangle shape, not pointed in the least
some photos showing the wire lengths
jpg  a.jpg (119.56 KB)
174_67df2a19105d7.jpg 1600X1132 px
jpg  b.jpg (128.50 KB)
174_67df2a2097527.jpg 1600X1187 px
jpg  c.jpg (110.91 KB)
174_67df2a3520f46.jpg 1599X1244 px
Posted on: 2025/3/22 21:23
Those above amber front lights are missing the grommet
The front light has two wires going to the lamp socket. Even though front and rear use the same bulb, the sockets are constructed very differently
jpg  With the grommets intact.jpg (155.02 KB)
174_67df604d9e05e.jpg 1164X928 px
jpg  front oval lamp socket.jpg (95.81 KB)
174_67df60575d9df.jpg 1178X844 px
Posted on: 2025/3/23 1:14
Re: Side Markers - REAR RED North America
The rear lamp socket is grounded to the lamp housing. The earth ground wire is crimped to the body, and a single wire goes to the socket center
both front and rear use the same bulb: 8W single-contact bayonet BA15s base with G6 globe
The traditional replacement is the 9.3 watt type 97 bulb
jpg  rear, crimped earth wire.jpg (88.10 KB)
174_67df6fc399e37.jpg 1312X720 px
jpg  rear lens taper.jpg (95.07 KB)
174_67df6fcd45d76.jpg 1200X1067 px
jpg  rear gasket taper.jpg (97.54 KB)
174_67df6fd682934.jpg 1352X1067 px
jpg  Wagner 97 bulb.jpg (27.96 KB)
174_67df6fde3d1f5.jpg 499X920 px
Posted on: 2025/3/23 2:21
Even late model (black rim version) use the grommet. Most aftermarket lamps lack this part
jpg  Lamp with wire grommet.jpg (46.41 KB)
174_67df848ea69fa.jpg 640X480 px
jpg  Black rim late 1200.jpg (84.93 KB)
174_67df849374276.jpg 640X480 px
jpg  Lamp assembly.jpg (85.17 KB)
174_67df849d4e02a.jpg 640X480 px
jpg  twist-lock lamp socket.jpg (55.51 KB)
174_67df84a8552e1.jpg 640X480 px
Posted on: 2025/3/23 3:49
