WTB stock nylon cooling fan.
From Las Vegas USA
As the ad says I'm looking for to stock 4 blade nylon fan.
Posted on: 2018/8/6 1:44
Re: WTB stock nylon cooling fan.
there are two kinds, for use with the short or long water pump
both 310mm but with different offsets
Posted on: 2018/8/6 2:14
From Mordialloc Victoria 3195
Have plenty but probably not worth sending to the US.
Posted on: 2018/8/6 3:22
keep it simple
From Sydney NSW
Out of interest DD I had an adapter for extending the snout on the pulley, perhaps for adapting the different offsets. That was from an A15.
Posted on: 2018/8/6 4:22
From Las Vegas USA
Dave I can use either one as I have the spacer and hardware.
Zigmono I'm in Las Vegas and the 45C we regularly see does the fans no good, if you want to see what it would cost to ship one I maybe up for it.
Posted on: 2018/8/7 2:26
elemental_funk, the adapter is for the short pump. It requires the shallow offset fan. I ran into this problem in 2012, to use the other fan the water pump must be changed
Posted on: 2018/8/7 4:52
