dyno test - points vs. coil pack
Skid Factory tests NIS016 with fully-programmable ignition and finds it doesn't make appreciable HP gain. At a certain max-HP RPM it was pretty much the same
Points distributor can be adjusted for max HP easy enough, so it's not surprising. But what about at lower RPMS? The programmable ignition may be doing better. I think it would only help acceleration if the timing is optimized at all RPMs
The test was done with twin webers and what looks like an SR20-type CAS
V I D E O: Carb vs EFI on an L Series Datsun 1600 - Dyno Test
Posted on: 2018/8/7 6:08
Re: dyno test - points vs. coil pack
more reason to have full mech setups at the famous tracks to stick it to most peoples slavery to technology
Posted on: 2018/8/8 8:28
