Browsing this Thread:
1 Anonymous Users
for the bluebird fanatics, a real rare bird |
Posted on: 2018/8/19 1:45
Re: for the bluebird fanatics, a real rare bird |
Posted on: 2018/8/19 9:21
Edited by unfamilia on 2020/3/29 12:17:48
Registered Users Contentmaster Usermaster
Ah the first FWD bluebird, model series U11. The SSS Turbo wagon came with a sizzling 88kw powerplant. The CA18ET only had two valves per cylinder. Looks like the Series 3 910, but is actually the U11 new generation
Bluebird didn't get AWD until the U12
Kind of interesting in 1985 (especially for a wagon), but considered old tech in just 2-3 years
Posted on: 2018/8/19 11:16
Its a rare bird alright and I thought you guys over the pond had the 4wd sentra wagons? http://www.automobile-catalog.com/car ... _sentra_wagon_xe_4wd.html2 valves are better than 4 for everyday driving swirl beats tumble every day of the week when you mostly stay under 4000 rpm.
Posted on: 2018/8/20 14:44
Yeah we had Sentra wagons, but Sentra is Sunny not Bluebird
2 valves are better than 4? How do you mean?
Posted on: 2018/8/21 3:09
From Perth
But the question is... are 2 plugs better than 1
Posted on: 2018/8/21 12:33
8v heads do better from idle to 4000rpm with most cars never really going about 4k the 8v makes better torque for the street and if done right great for racing.
From a wise man's quote... with the depth of the valves in the chamber correct shaping can achieve very good velocity for quite a way into the chamber, so the incoming charge does not 'stack up' as it drops velocity into the chamber but follows the piston down the bore resulting in most of the mass (& pressure) in the chamber being as close to the piston crown as possible (& as far from the fresh incoming charge as possible) allowing fill to continue well past BDC and assist pressure recovery. You can't do that with 4V heads, that's why they are known as 'tumble & dump' heads, most of the pressure resulting from the incoming charge dropping velocity ends up high in the chamber & impedes incoming charge.
He achieved 142hp per L from a 2v head
twin plugs for sure even better for hemi style chambers as used by Alfa, Abarth and Citroen.
There is an alternative for the 4v heads by using irregular inlet camshaft profiles where one inlet stays closed until a certain rpm, this can also create swirl if done right.
Posted on: 2018/8/21 17:06
Yes. On the other hand, most guys here want the most peak HP, even if torque (lower RPM HP) suffers. Couldn't Tony could get more than 142hp/l from 8V head? Even production 4V can make 126hp/l
Posted on: 2018/8/28 22:47
Thats not any production 4v head that gets 126hp majority of production 4v heads struggle in general but everyone has to have the 4v heads sales pitch when 2v is fine for most applications. The engine Tony built competes and destroys other 4v heads and double the capacity v8 race engines so there it has a torque curve for its size that is superior to all other race engine it competes with. Even the best NA nissan L6 2v cannot crack 120hp per litre and even versus an Rb26 of any kind that Bmw engine with 2v decimates them all.
Posted on: 2018/8/29 2:39
Ferrari 458 uses 4V heads, get 126 hp/litre naturally aspirated. And meets emissions and runs on common pump fuel
Posted on: 2018/8/29 3:46
