Browsing this Thread:   3 Anonymous Users
belt drive A series kit
I know Ive seen somewhere on this forum a belt drive kit
to replace chain setup on A series but does anyone know
if a similar system was used on an L series?
Owner makes 180hp atw with fia head I supplied but wants
to extract every hp out of his class winning 510
Posted on: 2018/9/11 13:47
Re: belt drive A series kit
Here's one should be less friction than a chain
Posted on: 2018/9/16 4:07
Sweet is that datto A series?
Posted on: 2018/9/16 6:57
Yes. It says it is against TS regulations
Posted on: 2018/9/16 10:44
Have you got a link to that site please DD? I would be interested in having a look at one of those setups.
Cheers
Dave
Posted on: 2018/9/16 23:35
Unfortunately not. It came out of a magazine which I no longer have
Posted on: 2018/9/17 2:04
I prefer the belt driven setup DD
but cant find the pic of it.
Belt setup should be lighter albeit
not as accurate but its only for
an oil pump if you are running
distributorless dizzie ecu
Posted on: 2018/9/17 5:11
I'm not aware of any belt drive to replace chain setup on A series. The good news is that the oil pump still works after distributor is removed on the A series (unlike the L-series)
Posted on: 2018/9/17 10:19
I thought you posted it about 15 years ago
Posted on: 2018/9/17 13:18
i ran my A12 with the distributor removed for about two years, had good oil pressure the whole time
perhaps you are thinking of an accessory belt drive. The V-belt can be replaced with a gilmer drive belt
Posted on: 2018/9/17 20:57
