« 1 (2)
Re: SR20VE versus 3SGE
True, but sometimes heavy parts work well in a 1200
Posted on: 2018/10/16 8:09
Fj20et weighs the same as an LS v8
Heres is a beauty L series roller rockers!
http://web.archive.org/web/2016050420 ... atsun-l-series-build.html
Posted on: 2018/10/16 8:59
Edited by D on 2018/10/16 14:46:54
A BRE L18 race engine weighed around 109kg down 10 from stock
thanks to flywheel/clutch, knifed crank, titanium rods, forgies
titanium retainers, valves and cleaned up block castings.
Good thing is a sleeved Sr20de bottom end weighs 24kg around
14kg less than an L16 bottom end of 38kg. Bore spacings and
water jackets are easily matched then you have a 95kg hybrid
SRL20 that using lighter Keihins no dizzie as SR has modern
independent oil pump and still chain driven probably lighter
than an A14 and FIA L heads sometimes come up for under 1k usd.
Posted on: 2018/10/16 14:56
Does the 3SGE look this good?
SR20VE with ITB throttle bodies
jpg  SR20VE NEO VVL in 2008 bakkie.jpg (100.21 KB)
174_6929e00fdbc22.jpg 1024X768 px
Posted on: Yesterday 17:46
« 1 (2)
