What are alternatives to the front wheel hub of a B210 coupé 1974?
Not too shy to talk
From Kenya
Hi guys? This forum has become so pivotal in my build. I joined the site in 2014 when I first got my car and now since then I've been saving up for an engine swap and I decided tO start with brake upgrades. Ddgonzal has been very helpful on my previous topic too. My question is, what alternative hubs are there since I cannot source B210 front wheel hub on rockauto? Can the stanza rear hub serve as an alternative? I already bought the front rotor discs. But one of my hubs is faulty.I'm still using stock strut. TIA
Posted on: 3/15 6:23
Re: What are alternatives to the front wheel hub of a B210 coupé 1974?
From Hawaii, USA
Is your B210 an original A12-powered version or is it a 1400?
Posted on: 3/15 9:33
From Hawaii, USA
Not too shy to talk
From Kenya
A12 powered. Looking to put a bigger engine later. SR20 most likely.
Posted on: 3/15 9:51
From Hawaii, USA
For 1973-1975 B210 A12/120Y there are two hubs
For original drum-brake (type 180) or original disc-brake (type H10)
They can be swapped but those are the original types
They are the same as 1970-1973 B110 and 1971-1975 B120 bakkie/truck (drum brake type)
They are not sold in USA we need to find them as used parts -- or from a recyling place
Posted on: 3/15 10:53
Not too shy to talk
From Kenya
Other than those you mentioned, there are no other alternatives?
Different question, just to confirm, the Hilux caliper fits without modifications right?
I read here they have same bolt spacing as 120y/B310? Hilux calipers
Posted on: 3/15 15:45
From Hawaii, USA
B310 has different spacing than 120Y
Are there other hubs for the early A12 B210? Those are the only ones that bolt on as far as I know. B110, early B210 and early B120 all use the same hubs ... also 1966-1970 Datsun 1000 (B10) uses the same hubs
Alternatives:
* You can fabricate new hubs, or pay a machinist to fabricate them, based on the old hubs
* You can swap the strut assemblies (including the hub and brakes). See Strut Swaps
Posted on: 3/16 7:27
