Your thoughts on electronic dizzys?
I’ve come across these after market electronic distributors to fit a12-a15 on eBay. Has anyone brought one, how do they go? Much of a benefit? Any info would be great. Thanks
Posted on: 2019/4/29 11:22
Re: Your thoughts on electronic dizzys?
From Tamworth, NSW
Would like to hear feedback to.
They are cheap and should make for easier starts and more power.
I wonder if the have the correct curve?
Posted on: 2019/4/30 0:17
Project coupe:
Just drive it
dont make any more power, nor run any better than a correctly adjusted points ignition
But, will run well for years without any need to re-adjust every six months and buy new points/condensor every year
Posted on: 2019/4/30 7:48
Posted on: 2019/4/30 8:09
Edited by unfamilia on 2020/3/29 11:55:17
electroin dizzy not electroin disco
I see these ones on eBay right now, they mostaly all look like the same unit from China. Doesn't look like any Nissan-Datsun unit that I know of. Cap & Rotor is unknown too
Some have new-type A-series hold-down plate, and some have Austin-style (adjustable) hold-down plate. Some show both plates in the ad, maybe it comes with both?
Some are listed as 22100-H7860, but that is a Datsun points distributor
jpg  aftermarket.jpg (95.30 KB)
174_5cc800e7820a7.jpg 1000X1000 px
jpg  s-l1600.jpg (176.50 KB)
174_5cc803183a912.jpg 1257X650 px
Posted on: 2019/4/30 9:11
From Kyoto Japan
cap and rotor the same as late sunny truck (elec) and late vanette(points)\
Posted on: 2019/5/1 16:04
guard mirrors, whitewalls.....life's almost complete.
Club Sunny Truck - REPRESENT!
Hayashi Racing
Secret Factory Japan
From Tamworth, NSW
I though that electronic ignition gave you a higher voltage spark because it didn't require a ballast resistor or is that just sales talk from the Hotspark/ retro fit crowd?
Posted on: 2019/5/2 1:59
Project coupe:
Just drive it
According to the Hotspark web page, it *requires* a ballast resistor, or a coil with the same resistance built-in (which they are happy to sell you)
Same with Pertronix. Although there are plenty of guys who use them w/o the resistor and it (mostly) seems to work
Posted on: 2019/5/2 8:49
From Adelaide
If you run a coil without ballast resistor and it needs one it'll overheat and fail. I had it happen on my Datsun and got stuck far from an Auto shop. If the electronic distributor self limits current then you can delete the resistor. The ballast is usually bypassed during cranking to compensate for voltage sag.
Posted on: 2019/5/2 12:06
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Mordialloc Victoria 3195
I have them on all my N/A motors and never had a problem.
No noticable power increase but simple to wire up ( just need an extra +ve 12v to them )
I bought the ones with compatable coils for an extra few bucks
dp
Posted on: 2019/5/2 23:12
keep it simple
