1973 Cylinder Head
From Fort Worth, Texas
Buddy of mine picked up a 1973 1200 car. He says it has original early A12 engine with 4 speed. Plans to pull both engine and gearbox out and no use for it. Cylinder head has no markings. Any idea if this is open or closed chamber, round or oval ports? Can't tell if it has double valve springs from pictures. He said manufacture date is mid 1973.
jpg  1973head.JPG (142.48 KB)
20677_5d75b96731098.jpg 768X1024 px
jpg  1973head1.JPG (199.55 KB)
20677_5d75b9728b835.jpg 768X1024 px
jpg  1973head2.JPG (139.57 KB)
20677_5d75b97938f1e.jpg 1024X768 px
jpg  1973head3.JPG (134.64 KB)
20677_5d75b98603821.jpg 1024X768 px
jpg  1973head4.JPG (148.61 KB)
20677_5d75b9915f8e4.jpg 1024X768 px
jpg  1973head5.JPG (168.61 KB)
20677_5d75b99e7a6da.jpg 768X1024 px
jpg  1973head6.JPG (180.33 KB)
20677_5d75b9a77c61c.jpg 768X1024 px
jpg  1973head7.JPG (131.37 KB)
20677_5d75b9ae96c3f.jpg 1024X768 px
Posted on: 2019/9/9 3:35
Re: 1973 Cylinder Head
Good questions
* In USA, orginal A12 (1970-1973) was the only A12 ever sold in this country
* Only the 1971 came with closed chambers
* Dual valve springs were not used in USA, but certainly could have been purchased from Datsun Competition and installed. A photo from the side will tell
* Unmarked head is either A12 or A12GX. I see a carburetor peeking out of the edge of the photo with the 1973-or-later anti-diesel valve. It appears to have all the stock 1972/1973 emissions gear
Posted on: 2019/9/9 3:55
Thanks DD. So then this would be an open chamber meaning lower compression? And does it have round or oval ports? I have seen the GX heads with the "Japan Nissan" stamp. Some GX heads do not have this writing?
Posted on: 2019/9/9 4:36
Open chamber does not mean low compression. With the A-series engine, the compression is mainly due to the piston dish (3 different pistons were used on B110s)
29cc A12GX head
31cc A12T GX head
28cc A12 Closed chamber
Compare to 30cc H89 Closed chamber
9.0:1 1971 North America (69 hp)
8.5:1 1972-1973 North America (68 hp)
1972-1973 north america used open chamber with a deeper dish piston
Closed chamber is more efficient, more resistant to detonation. It's good for 1 hp on regular gasoline, and 3hp with flattop pistonz and premium unleaded. But closed chambers also creates more NOx pollution which is why it was changed to open chamber
All A12 heads are round-port -- except A12GX and A12T. I believe all GX heads are cast with "JAPAN" and "NISSAN" on the top of the head
This is the open chamber 1972-1973 head
Posted on: 2019/9/9 10:40
Appreciate the info DD. So in 1974, the A13 was introduced and later years with the A14 and A15. This particular engine is an early A12, dizzy below #1 plug. What years and what vehicles came with the late A12 engine? I am familiar with the A12A that was offered in the 210 beginning in 1978.
Posted on: 2019/9/9 15:43
Late A12 engine came in non-USA B210, Vanette, B310 Van, Cherry, F10
Posted on: 2019/9/9 20:36
