Browsing this Thread:
1 Anonymous Users
datsun 60L dogleg striker lock pin removal |
hi guys..
i am trying to remove the strike lever lock pin from 60L 5speed (dogleg) For standard H pattern 60A, its easy to knock from the reverse check sleeve hole.
need help on the best way or a tool to remove the lock pin.
thanks
Attach file: striking rod.png (25.93 KB)
Posted on: 2019/9/21 18:55
Re: datsun 60L dogleg striker lock pin removal |
Registered Users Contentmaster Usermaster
Here's the parts diagram
Looks like it is tapped out * remove nut, washer & lock-washer * using a drift, gently tap pin from Nut side Because the threads are right there, be careful when using the drift
Can you post photos of this mechanism?
Attach file: STRIKING ROD D32-04a.jpg (41.30 KB)
Posted on: 2019/9/21 21:46
The diagram lists "O-RING" but I think it is a thrust washer??? Only the FS5W60L has it
Posted on: 2019/9/22 0:17
Also the STRIKER has two pins & two nuts I think
1. Fastens BRACKET to STRIKING LEVER 2. Fastens STRIKING LEVER to striking rod
I have this photo of 56A 5-speed, it is similar although the BRACKET is much different
First remove bracket bolt, bracket, and pin Then remove lever bolt, washers and pin
Attach file: SHIFT ARM BRACKET (F5C56A) 0610-1.jpg (47.20 KB)
Posted on: 2019/9/22 0:25
managed to remove it by tap with small hammer. oring and oil seal are there.
ps: some photo i can only upload in gif file. poor quality
Posted on: 2019/9/22 6:36
Those photos are very clear. They are small, but good quality. Thank you
Posted on: 2019/9/22 10:02
thanks
Posted on: 2019/9/23 6:44
