« 1 (2)
Re: B210 Round Gauge Dash Electrics
Thanks Curtis. Excellent info.
(see what I did there?)
Posted on: 2017/9/18 7:30
From Sydney
Also i did it with the dash and frame out of the car. I dont think it would be fun trying to do it with it still bolted in.
Posted on: 2017/9/18 9:31
So I'm assuming the round gauge dash harness is different and would be required to fit the gauges? I'd love to see the schematic for the pb210/gb211/b210gx/b211gx etc.
Posted on: 2017/11/9 11:46
From Hawaii, USA
mine ... has the brake and oil pressure light. Also I have no clock just a sunny blanking plate no wood grain either
Yeah, clock was an option -- normally a blanking plate covered the hole. No tachometer or large clock on the DX Coupe, just a blanking plate. Small clock was for GX otherwise a small blanking plate
wood grain may be a PB210 thing
Round-gauge dash came in JDM (B210 and PB210) Coupes & GX Sedan
Identification:
* 160kph speedo: DX, GL
* 180kph speedo: GX
* 7000 rpm redline: PB210 (L-series engine)
* 6400 or 6800 rpm redline: B210 (A-series engine)
I see that some have a BRAKE indicator light, that came into use OCT 1975 for the B120, maybe the same date for B210
Posted on: 7/24 19:50
From Hawaii, USA
Me too, i've never seen a JDM wiring schematic only the B122-R wiring diagram that Endo sent me
Wiring harness: round-gauge and square-gauge dash harness ("instrument harness") differs. Difference unknown but id guess its the connectors for the supplemental gauges which are only there on the round dash
Posted on: 7/24 20:04
From Hawaii, USA
This is the document that generally has a full wiring diagram. Nissan Service Bulletin. Also has some schematics, mostly for new or changed items. I had a couple of these for the 1200 and they have stuff you won't find anywhere else (e.g. why does the intake manifold runners have grooves in them ...)
Like this one went for $8
https://buyee.jp/item/yahoo/auction/d347429489 search
It's for the changes that came in OCT 1975 namely H- and A- level Japan Emissions but I expect because it says "introduction" that it will have full specs and wiring diagram (and especially so since it is 106 pages)
If you want to see one of these complete, look at the Service Bulletin 350 Introduction of Datsun Sunny 1400 GX-E -- although that one doesn't come with a full wiring diagram (it's less than 60 pages)
jpg  293 S-16 A-PB210, H-VB210 introduction OCT 1975.jpg (93.42 KB)
174_5d392857d1f4b.jpg 701X859 px
jpg  293 models.jpg (152.52 KB)
174_5d39288c2b668.jpg 768X1024 px
jpg  293 engine.jpg (143.07 KB)
174_5d3928a2222c9.jpg 1024X768 px
jpg  293 Check Connector.jpg (143.28 KB)
174_5d3928acce8d0.jpg 1024X768 px
jpg  293 Cat with temperature warning lamp schematic.jpg (151.63 KB)
174_5d3928c2b1502.jpg 1024X768 px
Posted on: 7/25 5:19
From Hawaii, USA
Curtis' dash is the the regular GX gauge package -- a full set of guages
plus it has the OIL and CHG warning lamps in the speedometer
jpg  Dash Harness connector 20161023_123216.jpg (65.40 KB)
174_5d3df79a6bd5a.jpg 768X1024 px
jpg  Full Gauges 20161023_123127.jpg (118.29 KB)
174_5d3df7a384903.jpg 1024X768 px
png  PB210 gauges 224-02.png (131.76 KB)
174_5d3df80e600be.png 1229X731 px
Posted on: 7/28 20:31
I wonder if you use could use the ordinary harness? The main cluster and tach should be fine.
Then make a little connector from the clock plug to share with the Amp/Volt meter, and the oil gauge. Then just add a wire from the oil pressure sender to the oil gauge. The Amp meter has extra white and white/red wires. The volt meter just has one plug like the clock.
I have the dash and all gauges just no harness.
Posted on: 10/16 9:00
From Hawaii, USA
Sounds do-able
If you modify the stock harness to work with autometer gauges it should work with Nissan
Posted on: 10/18 8:45
From Hawaii, USA
Meant to say ... if you CAN modify a stock wiring harness to work with aftermarket gauges like Autometer gauges -- which is done all the time -- then you should be able to make it work with Nissan gauges
jpg  476382772_1.jpg (43.63 KB)
174_5dacd35876984.jpg 640X480 px
jpg  d226311990_2.jpg (59.33 KB)
174_5dacd36ca81b4.jpg 928X768 px
jpg  d226311990_3.jpg (44.99 KB)
174_5dacd37364013.jpg 832X800 px
jpg  d226311990_1.jpg (45.89 KB)
174_5dacd380b5f51.jpg 862X448 px
jpg  476382772_5.jpg (43.94 KB)
174_5dacd39d69356.jpg 640X480 px
Posted on: 10/20 22:38
« 1 (2)
