Thread and hose barb size
Hi Guys.
Could someone please tell me what both the thread and hose barb sizes are for the two fittings the bolt into the head at the two points indicated? I know the rear one is 90degrees while the front is straight but if someone could shed some light that would be great.
jpg  Untitled.jpg (49.25 KB)
15715_5dae30057936d.jpg 552X291 px
Posted on: 2019/10/21 23:26
Re: Thread and hose barb size
The one at the rear of the cylinder head is:
* 27070-H1000 CONNECTOR-WATER INLET
OR, for no-heater (STD) models:
* 00931-30610 PLUG-HEATER OUTLET HOLE
For sale on eBay now
As you can see they are taper threads. The hose barb is 17.5mm over 16mm O.D. tube (for 13 mm I.D. hose)
jpg  27070-H100.jpg (37.73 KB)
174_5daebf1cd9901.jpg 574X468 px
Posted on: 2019/10/22 9:34
The front one is the temperature sender (or as Nissan calls it the "thermal transmitter"
M16 x 1.5 threads
The original is a two-piece type with a threaded collar
newer versions are a one-piece type with the threads cut into the transmitter
jpg  24849a.jpg (41.37 KB)
174_5daeec5e51b94.jpg 800X600 px
jpg  25080-89900-1.jpg (43.61 KB)
174_5daeec67a8849.jpg 800X640 px
jpg  25080-89900-1-1.jpg (40.96 KB)
174_5daeec6f34ed7.jpg 800X640 px
jpg  T1181.jpg (22.57 KB)
174_5daeec8059c40.jpg 900X380 px
Posted on: 2019/10/22 12:48
Thank you very much!
Posted on: 2019/10/22 22:18
1 x Baby Blue Ute
From Mordialloc Victoria 3195
BSP or NTP
Posted on: 2019/10/23 0:05
keep it simple
Neither, it is metric. You can measure the hole, then go to a hardware store or bolt store and get one the same size
The A12 is all metric except the early flywheel bolts and the oil sender threads as far as I know
Posted on: 2019/10/23 3:50
