HELP- A15 with original injection inlet manifold need help setting up
From Queanbeyan nsw 2620
hey guy
I have a A15 engine and recently purchased a original inlet manifold and need help getting it sorted, Ive always had datto my whole life but never played around with A series engine always rotarys my question is I have a LT-10s micotech computer left over from another car and getting it re maped… if anyone can help your input or anyones input who have down in a simpler way anything.. also where to get a inlet gasket as the injection on have that little spot at the top for the injector I would like to go the micotech way so I can control spark and fuel not just fuel anyways any help would be helpfully at the point to get started
Thanks Adam
Posted on: 2019/11/16 7:20
Re: HELP- A15 with original injection inlet manifold need help setting up
From Hawaii, USA
hi adam you can use a standard A14/A15 gasket and notch it. use the H89 type wet gasket (for manifold with water ports)
Posted on: 2019/11/17 21:06
From Hawaii, USA
Do you have the matching air flow meter and ECU? If so I would just install all the Nissan factory parts and get it running. Later you can experiment with modifications
jpg  airflow_meter.jpg (99.46 KB)
174_5dd1b9f6947a9.jpg 806X1000 px
Posted on: 2019/11/17 21:21
Hey mate yeah i have that part aswell .. tho Microtech got back to me and remap my computer LT-10s
I just need to find the guy on hear who is locking the elec dizzys up it and one knows him or knows where i can buy one from??
Posted on: 2019/11/20 16:23
From Kelmscott Western Australia
buy a14 inlet gasket and notch you also need to notch the head as well
Posted on: 2019/11/21 6:34
71 Datsun 1200 ute with A14 fuel injection
59 Morris minor ute with A15 fuel injected with Sc12 supercharger
From Hawaii, USA
locking the distributor is easy just put some JB Weld on the slots see our tech article and photo at Locking The Distributor
Posted on: 2019/11/21 8:20
Is anyone mass producing Turbo exhaust manifold or people just making there own?
Posted on: 12/3 1:37
From Hawaii, USA
chris produced turbo manifolds, but no longer
About the gasket, Datsun made seven different A14 oval port gaskets all shaped a little different
Use the H89 one although there isn't much material at the top so be careful how you notch it. I'd bolt it first to the manifold and mark it so you can remove just the minimum material for the notch. Using a thin but sharp chisel you can easily cut a rounded notch. Supplement it with a thick little bit of RTV above the notch (let it tack up before bolting together -- as per the directions on the RTV package)
14035-05H01 has superceded the H89 gasket and appears to have bit more room above the ports
Or you could use the GX gasket 14035-H2300, looks like no notching is needed
The original EGI gasket looks like this
14035-H9201
14035-H9202
Posted on: 12/4 9:10
